Author Topic: New to me 2011 Like 50  (Read 1867 times)
Mark James
« on: July 03, 2019, 12:55:25 AM »
Hello All,
Thanks for the info on the board.  I am the proud owner of a new (2 me) 2011 2t restricted barn find with 130 miles on the clock.  I completely drained the fuel/oil system.  Cleaned the carb, including some sort of larvae in the bowl, not sure how it got in there.  I will eventually get to the BBK.  It had a .7 main jet and I replaced it with a .82 gy6 jet I had laying around.  Started with 2 kicks and tops out at 27mph (verified by traffic radar) but it feels like the drive boss, which I have on order.   Electric start is not working but when I press the button it puts a very high draw on the battery so I figure it's something binding up the electric start gear.  I tried the old trick of tapping on the starter motor but it didn't work.  I will address this when my variator parts come in.
Here's my plan:
1.  smooth Drive boss
2.  6 gram dr pulleys
3.  1500 spring
I will keep the board updated.
« Last Edit: July 13, 2019, 07:40:04 PM by Mark James »
Tao Tao 50 (sold)
Kymco Super Fever (sold)
Piaggio Fly 50 (sold)
Kymco Like 50
-Malossi BBK
-19mm keihin clone 92,38,needle clip 5
-original muffler with restrictions removed
-Polini variator w/8.5 rollers
-runleader temp/tach
Kymco Like 200i (parts bike)
Re: New to me 2011 Like 50
« Reply #1 on: July 03, 2019, 01:10:53 AM »
Welcome!
And good luck with your project.
Viper254
  • Moped Pirate
« Reply #2 on: July 03, 2019, 10:20:36 AM »
Might be worth popping the starter motor off, cleaning up all the insides and popping it back together. My CLR125 (Honda) used to suffer in that way!
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
eamartin
« Reply #3 on: July 03, 2019, 07:54:50 PM »
Is the starter getting the necessary voltage? Pull it and bench test it before disassembly.  Even if it bench tests okay, I'd disassemble, clean and lube before re-installing.
Mark James
« Reply #4 on: July 11, 2019, 10:44:09 PM »
When I opened up the variator cover it was just as I suspected.  A couple rodents got in through the vent hole and nested.  Cleaned it out, lubed it and all is fine now with the electric start.
25 mph    1500 spring, 6 gram sliders and smooth boss
30 mph  oem spring, 6 gram sliders and smooth boss
35 mph   oem spring, oem rollers, and smooth boss.
39 mph   oem spring, oem rollers, smooth boss, muffler restrictions removed (from http://www.kymcoforum.com/index.php?topic=11962.0), 88 jet, air restriction removed from air box.
Hesitates a little on acceleration which on my gy6 indicated it was running rich.
« Last Edit: July 13, 2019, 07:43:20 PM by Mark James »
Tao Tao 50 (sold)
Kymco Like 50
-Malossi BBK
Ajayprasad
« Reply #5 on: July 19, 2019, 11:17:21 AM »
I recently got a new to me 2011 Like 50 2T as well. From what I assume was stock, 35 mph max. I removed exhaust restrictions and got an unrestricted CDI, max about 45 mph. I got a smooth unrestricted boss next and took out the washer. Back down to 35 mph tops. I just changed to 6.0 g rollers and replaced the washer, 40 mph. I thought I'd take the washer out again, 35 mph. I don't know but some OEM parts seem to be better. I'm about to clean the carb and switch some things up. I'll keep you posted.
« Reply #6 on: July 19, 2019, 11:51:47 AM »
Welcome Ajay....!
And let your experience be a bit of good info to those 50 owners who assume Kymco isn't as clever. There does seem to be a few more MPH's in a 2 stroke if it is done correctly. One mod at a time.....
Thanks for your post.
Ajayprasad
« Reply #7 on: July 19, 2019, 01:32:36 PM »
Thank you. Any helpful advice?
Mark James
« Reply #8 on: August 30, 2019, 05:12:55 AM »
Here's where I am at:
43 mph (flat, no wind) oem spring, 8 gram sliders ($6 dr. pulley clones), smooth boss, muffler restrictions removed (from http://www.kymcoforum.com/index.php?topic=11962.0), 85 jet, air restriction removed from air box.
Just as fast as my BBK Gy6 (not including hills).
Tao Tao 50 (sold)
Kymco Like 50
-Malossi BBK
