Author Topic: How to change the oil on a X-Town?  (Read 4412 times)
General Zod
« on: July 06, 2019, 11:18:11 PM »
Does anyone know how difficult it is to change the oil and filter on a 2018 XTown 300?
have a dealership that's about 40 miles away that wants to charge close to $50, and that's just waaay expensive IMO
Re: How to change the oil on a X-Town?
« Reply #1 on: July 07, 2019, 11:38:57 AM »
With dealer 40 miles distant - it is time for you to obtain a couple of inexpensive tools and a service manual for your scooter.
Regarding an engine oil and filter change - most owner's manuals walk you through this procedure, with illustrations.
Get down next to your scooter, using manual locate filter and drain plug.
So, what do you think....can you do this?
If you're really uncomfortable doing this simplest of all scooter servicing - then make an appointment with your dealer.
Most dealers charge @$100 an hour for labor....oil plus filter and labor for $50 does not seem unreasonable for a scooter or motorcycle.
Seem more expensive than a car oil change --- sure it is. There are dozens of oil change places in even a small town. Unless you are in the Philippines or Vietnam. .......your scooter dealer has very little competition for price setting.
« Last Edit: July 07, 2019, 11:43:59 AM by Stig »
« Reply #2 on: July 07, 2019, 12:09:15 PM »
Since when does XTown have oil filter?  my 2019 has none---oil change requires 17mm wrench (box better for me), drain bolt on left-----one right side it requires 17 mm to check screen---socket works better. I, after initial check plan to check screen every 10,000 miles.
Long engine life on XTown---with its one quart crankcase capacity---change oil often!  When just doing local trips, I change every 1,000 miles---long trips where lots of miles are put on in a week or two, I tend to let it run longer.
For me, the last 500,000 2 wheel miles---WalMart house brand 10-40 has worked fine.  Cheap/available just about everywhere in US.
My 2019 now has 7500 plus miles.
General Zod
« Reply #3 on: July 08, 2019, 04:07:13 AM »
I use to have a 2010 Xciting 250cc and changed the oil all the time and it had no filter, just that little cone shaped screen thing
I called my dealership and asked them and they told me the OIL Filter was $8.95 and I have tried to look up to see where I can buy one myself and cant find a oil filter to buy
If your saying there isn't one, then that is awesome. I can then change it by myself like I use too.
« Reply #4 on: July 08, 2019, 10:36:16 AM »
Dealer told you that, huh? OK, boys, hold me down! This will get me started on dealers!
« Reply #5 on: July 08, 2019, 10:55:32 AM »
He was probably referring to that screen thing. ( my mistake on the filter. Many 300s have some kind of filter, internal or spin-on. Guess Kymco deleted that on this economically priced 300)
« Reply #6 on: July 08, 2019, 12:32:25 PM »
Yeas! The DT, People 300i and the Yager all have a tiny cartridge filter to really filter the oil. It is a nice, serious touch.
« Reply #7 on: June 15, 2020, 11:04:51 AM »
Thank you John.  No picture of engine oil drain bolt in my XT300 owners manual (or on t'internet), but your information above let me locate it immediately, so grateful appreciation from a fellow XT owner!
« Reply #8 on: July 06, 2020, 04:18:19 PM »
Just changed the oil and just before refitting the drain plug a thought occurred. Do any of you switch to the prop stand to drain the last bit of old oil out?
TBR125
  • East Tennessee, USA
« Reply #9 on: July 06, 2020, 06:22:15 PM »
I usually raise both stands and hike it as far over as I can. May not be as easy on the heavier downtown and doesn't get much more out. Getting the engine hot and then letting it drain overnight seems to have a more pronounced effect.
« Reply #10 on: July 07, 2020, 10:39:39 AM »
I'll try the overnight tip next time!
« Reply #11 on: July 07, 2020, 01:28:11 PM »
When changing oil I just drain  and make sure screen is clean and have a glass of tea go back and put the drain plug in and fill with T-6 synthetic.  No more dirty oil then  left in engine isn't a issue.  I don't let my oil get that contaminated.
