Author Topic: hello everyone! 2002 kymco cobra need help no start no nothing  (Read 943 times)
hundacobra
i just brought this 2002 kymco cobra and im having trouble there is no power as in battery is full i put the key in no lights no nothing on the dash ,even the horn wont work .doesnt even try to start it just seems dead. ive been all over the web trying to find a repair book but keep coming up to dead ends .so please if anyone can help me out i will be for ever greatful. oh ive been told it has big bore kit 70cc or 71 cc i look up the words on the cyc. head and it seems to be true and was told it had racing clutch and variator but i havnt comfrim that yet .it looks like its been layed down so i dont know if their is a safety cut off switch or not when its wreck .i tried looking up the wiring diagram but having no luck .but once again thank you for your time and hope to hear from you guys soon   :D
Re: hello everyone! 2002 kymco cobra need help no start no nothing
« Reply #1 on: July 10, 2019, 01:52:07 PM »
Was it running when you bought it?
hundacobra
« Reply #2 on: July 10, 2019, 01:57:31 PM »
no it was part of a package deal . he was moving out and couldnt take that with him and the other stuff in the garage so i bought it all.he just said its been seating for awhile . and thank you so much for the reply !
DryFly
« Reply #3 on: July 10, 2019, 04:12:29 PM »
I don't know if this will be of help, but if you just got it and it's been sitting for a while as the PO said, how do you know if the battery is "full"? If it's the battery that came with the bike that would be the first suspect. Even if you charge the battery, it could be so fried that it won't hold a charge at all. Do you have a multimeter?
dwarf8
« Reply #4 on: July 10, 2019, 08:24:27 PM »
Hey Hundacobra
Where are you located?
I am in Ottawa and I am new to scooters but very old to motorbikes.
If you are in range I am willing to come over and have a beer and watch you get frustrated.  ;)
Ian in Ottawa
« Reply #5 on: July 10, 2019, 09:30:22 PM »
I'd start with a new battery. Get it to turn over.
Then you'll have to deal with effects of old gas.....and maybe the crash.
hundacobra
« Reply #6 on: July 10, 2019, 11:51:10 PM »
hello everyone !!!!!!!!!!!!!! so glade to see so many replies ! i do own a muti meter and ive been probing around ;) i think i have couple suspects besides the battery like the ignition switch or the relay .and i live in columbus in. all is welcome to come watch me get raged at this lol but ive done a couple of test but even if it had 9 volts on the battery it should still light up something right ?but nothing happens thats why im thinking its a ignition switch cause thats the start of the power ? the relay is to start it and the fuses are fine .so as far as i know that would be it .but i do have another battery i could hook up but its way bigger its for a power chair . its 12 volts and like 35ah so it shouldnt fry anything right ? once again thanks again for the replies and hope to hear from you guys again soon !hope to get it running and take some pics and vids for the group !
hundacobra
« Reply #7 on: July 10, 2019, 11:58:56 PM »
also once i get it running derestricting is next on the list ive seen that cutting the green wire on cdi .then crab ,intake,exhaust but im sure there is a write up on how to for that. for my 2002 cobra
hundacobra
« Reply #8 on: July 12, 2019, 12:16:53 AM »
bump
 look to see if i can use the power chair battery without harming the scooter .and any other info to help get this cobra biting again
« Reply #9 on: July 12, 2019, 12:42:45 AM »
As long as it is 12 volt, no problem. Should crank a small engine for a whole day or to when the starter catches fire!
Louder North
« Reply #10 on: July 12, 2019, 12:44:46 AM »
bump
You can use any 12 volt battery to try and start it.  Make sure it is 12 volts though and only to see if it turn over.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
hundacobra
« Reply #11 on: July 12, 2019, 06:59:35 PM »
ok im going to try that and ill be back with the results ! hopefully it starts !
hundacobra
« Reply #12 on: July 13, 2019, 03:33:44 PM »
UPDATE!!!!!!!!!! it turns over ! the starter is good but when i go to continuously have it turn over the start gear i think is pushing to for cause you will here is spin but the engine stops .so you have to stop pressing the button then press it again for it to engage . so im wondering if the battery i have in it is to strong or im missing a shim or a stop for the gear ? thanks again guys !
hundacobra
« Reply #13 on: July 13, 2019, 10:47:20 PM »
okay so if you hold down the starter button it will catch ..just takes it a min .but i got spark got fuel and went to start it smoke was coking out of the bottom gasket . took it off and it had failed so off to find where to buy one at
