Author Topic: Slow acceleration to 5500Rpm and very slow above  (Read 1806 times)
Szpilu
« on: July 19, 2019, 11:55:43 AM »
Dear All, I changed the Face drive+FACE COMP MOVABLE DRIVE+Belt(Gates). And buy a lighter rollers 14.5gr. But the scooter is very different the acceleration very slow to 5500Rpm then 5500-7000rpm more slower than the original setup.
What You think? the Original setup: Stock Variator Movable Drive+Face drive 15gr Dr Pulley rollers, Malossi belt,white malossi contrast spring.
2011 Downtown 300i white/black
Re: Slow acceleration to 5500Rpm and very slow above
« Reply #1 on: July 19, 2019, 03:18:03 PM »
Personally, I think the original, standard set-up on the DT300i is very hard to beat. Especially the stock Mitsuboshi belt: works good, lasts a long time. But then I am lazy!
xsel777
« Reply #2 on: July 19, 2019, 06:27:04 PM »
Shouldn't you rather fit heavier rollers to compensate for the Malossi spring, and the face, you replaced which I assume is different from what was on before.
Also the gates belt could be different dimensions, so behaviour  will be different.
« Last Edit: July 19, 2019, 06:28:58 PM by xsel777 »
Szpilu
« Reply #3 on: July 19, 2019, 08:24:49 PM »
Fu....k The different: 22110-LGE5 what is the stock and what I ordered 22110-LEA7 code. I changed back the LGE5 variator house with the new belt+lighter rollers. And I can fly :D
« Last Edit: July 20, 2019, 08:34:38 AM by Szpilu »
« Reply #4 on: July 19, 2019, 10:55:49 PM »
I really wish I could understand what you are saying....
Szpilu
« Reply #5 on: July 20, 2019, 08:31:38 AM »
The ordered variator house item number: 22110-LEA7 but my variator house is 22110-LGE5 what I need,the LEA7 the older variator vs my Downtown. Sorry if i wasn't clear.
It's was my mistake I didn't looked after what I need.
Forbes1964
« Reply #6 on: July 20, 2019, 12:40:53 PM »
If I understood correctly,he said. O oops wrong part.  Got the right part, all is well. [emoji23]
2009 Xciting 250
« Reply #7 on: July 20, 2019, 01:26:32 PM »
LGE5 is a designator for the x-town model not the Downtown which is LEA7. Maybe all understood that from the beginning but I am slower-witted than most!
KymcoRockr
« Reply #8 on: July 30, 2019, 05:25:50 PM »
No, just the opposite. Heavier contra spring and lighter rollers keeps the belt down in the variator longer and and allows the engine to work in the powerband.
AK550
Yager 200
