First off install the smooth Boss for the variator maybe 6.5gr rollers
Then install the 82 main jet that came with it.
install a 1000 rpm spring (Naruka makes a good one.
there is a washer that also restricts you in the Intake manifold (between carb and engine)
lastly if you look at your CDI next to your battery, remove the one of the purple wires with the red strip from the harness. This will remove the rev limiter
Outside that you will need to install a BBK.
