Author Topic: How to check the starter relay?  (Read 3815 times)
edog
« on: July 21, 2019, 05:12:40 AM »
The electric start has not been working for a few months. I can hear the solenoid/relay click when I press the starter button, but the motor does nothing. Battery is good. All lights work on the scooter. I want to test the relay to see if power is getting to the starter motor but can't figure out where it is located on the bike. I think it is under the plastic body frame, but I can't understand how to remove this frame. Please let me know what to do here... thanks!
Re: How to check the starter relay?
« Reply #1 on: July 21, 2019, 06:43:41 PM »
You don't have to remove much of anything to test the start relay. Hook a multimeter or test light to the starter motor + post and ground and watch when you push the start button.
edog
« Reply #2 on: July 21, 2019, 06:46:28 PM »
Thanks... I took all the body off and then found that it was a bad connection to the starter motor... lol!
« Reply #3 on: July 21, 2019, 06:48:21 PM »
Yow! I would not be 'laughing out loud!' I woulda been HOT!
big blue
« Reply #4 on: July 21, 2019, 06:54:55 PM »
For future use you can access a service manual here...https://www.manualslib.com/manual/393386/Kymco-Agility-125.html#manual
