Author Topic: Scooter starts but stalls when you give it gas  (Read 417 times)
AylmerFreerider
« on: July 22, 2019, 11:22:49 AM »
Hey all,  friend of mine pick up a scooter and he thought is was an easy fix.
The scooter starts every time but sputters at about 1300-1500 RPMs, but as soon as you try to give it some gas it stalls.
So things that have been done:
New spark plug, New Carb, New coil, New gas (super of course),  all grounds checked.
Now for some reason it worked for a day with no issue then the next day back to sputtering.  Caveat here is that is a 137QMB and not a 139QMB(GY6)
And ideas appreciated
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
hundacobra
Re: Scooter starts but stalls when you give it gas
« Reply #1 on: July 24, 2019, 12:04:38 PM »
it might be your fuel filter . and have you check for spark , make sure it was strong not weak(cdi might be going out).and have you tried adjusting the carb could be running rich or lean .you also might be having leak around your engine gaskets or your lines . with it running see if you can some or here any odd sounds or feel air being pushed out (and not from the exhaust lol) lmk if any of this helps and report back with what you find  so we can go from there..
AylmerFreerider
« Reply #2 on: July 27, 2019, 02:35:51 AM »
Turns out the CDI was defective.  Running well now.
2015 Super 8 50R
72cc BBK
