Author Topic: Variator nut  (Read 2730 times)
Ajayprasad
Variator nut
« on: August 02, 2019, 06:10:59 PM »
I got a locking tool that I swear doesn’t fit from buzzetti. I can’t find anything online about it. Also I are we reverse thread?
Re: Variator nut
« Reply #1 on: August 02, 2019, 10:21:06 PM »
No.
Try a $12 from ebay.
works on the LIKE200i.
245luigi
  • Boston, MA
Re: Variator nut
« Reply #2 on: August 05, 2019, 07:39:23 PM »
Use an impact otherwise you have to block the piston then turn the nut. No block take out the spark plug and feed in some rope, turn the piston until its blocked by the rope, then take off the nut with a socket/wrench. No reverse thread
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
Re: Variator nut
« Reply #3 on: August 05, 2019, 08:49:05 PM »
Which Buzzeti wrench did you get? The motorcycle clutch holding tool on Amazon looks like it would work well for less than 11 bucks. It's like what Stig suggested from ebay for a little over 12. I use a home-made one long enough to use the floor to stop the handle. That way  I can use a breaker bar and cheater pipe/extension on the breaker bar.
Re: Variator nut
« Reply #4 on: August 05, 2019, 09:14:32 PM »
Yes, use proper tool.
Jamming something against the piston....and then stressing every internal part until that heavy nut breaks loose does not seem like a good idea.
Nothing is stressed if using the proper holding tool in the proper position.
Ajayprasad
Re: Variator nut
« Reply #5 on: August 05, 2019, 10:48:03 PM »
This one, which is similar to others. I'm not the smartest person in the world but I couldn't find a way it would work without some modifications. It was not the right length or on the same plane. I took some washers and put them in between the tool and the frame; then I used vice grips on the top part to hold it in place.
245luigi
  • Boston, MA
Re: Variator nut
« Reply #6 on: August 05, 2019, 11:47:01 PM »
To my knowledge there is no tool like you linked for the Like. Instead of using rope, you could always use a piston stop which does the same exact thing
https://www.scooter-attack.com/media/catalog/product/cache/39/image/b8f0e7da4a117134976ad44a19bcff2f/m/f/mf9900055_mf9900055_01.jpg
Looks like that
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Re: Variator nut
« Reply #7 on: August 06, 2019, 10:57:34 AM »
Like Stig said that I will emphasize, piston stop IS A REAL BAD IDEA!! This thingy in your picture mates up with the ring gear behind the variator on the crank. This may or may not fit your machine. If your Buzzeti tool is the adjustable with the two pins that fit in the two holes in the front pulley just get a 2 foot length of water or gas pipe to slip over its handle and use the floor to hold it from turning while you use another pipe on your breaker bar to turn the nut to the LEFT. I have done this on three Kymco variators and it works. I have used an impact on a 50 cc Agility successfully. Just used short bursts and the nut came right off.
245luigi
  • Boston, MA
Re: Variator nut
« Reply #8 on: August 06, 2019, 09:41:44 PM »
I agree less than ideal. I'm not sayin that what you should always do but it'll get it done if you dont have the right tools. When I first got my scooter, I snagged one of those toold Stig linked and it didn't fit. I dont believe there exists one for the LIKE, at least in 2012 it didnt. So I had to do the ole rope trick. I then upgraded to the piston stop when I saw some fibers come off the rope and get stuck between the piston and cylinder. Finally I just spent some money on an impact and its been eazy-peazy ever since.
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
245luigi
  • Boston, MA
Re: Variator nut
« Reply #10 on: August 08, 2019, 04:07:22 PM »
The only problem is where do you put it. Here is the variator on a Like
https://imgur.com/a/NDp4hs0
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Re: Variator nut
« Reply #11 on: August 08, 2019, 07:06:40 PM »
Oops! That needs that gear tooth thingy doesn't it! Since I have been assuming it had a variator outer face with fan fins all over and two holes like nearly all the rest of Kymco models, I was all off base, huh!
eamartin
Re: Variator nut
« Reply #12 on: August 08, 2019, 10:42:54 PM »
Re: Variator nut
« Reply #13 on: August 08, 2019, 11:45:51 PM »
Something like that might work, Martin!
Viper254
  • Moped Pirate
Re: Variator nut
« Reply #14 on: August 09, 2019, 02:09:46 PM »
That's a tool for a four-stroke 50cc GY6 engine - which none of the Likes have ever been :(
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
