Author Topic: 7 mos on a tire plug  (Read 766 times)
« on: August 03, 2019, 01:22:37 AM »
Had a screw in center of a 1 year old Michelin Power Pure - plugged it with a "Stop & Go Tire" kit.... one of those mushroom headed plugs.
Checked the cold pressure this evening - still holding perfectly from the repair 7 months, & a couple of thousand miles ago.
mousejunks
Re: 7 mos on a tire plug
« Reply #1 on: August 03, 2019, 01:41:50 AM »
They do seem to last a while if done properly. My rear tyre has done at least 10,000km on it and probably has another 10k to go.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #2 on: August 03, 2019, 09:13:10 AM »
If plugged from inside probably ok way to repair tire----but after you go thru the BS to remove tire from rim on current scooters, except BMW, better just to fit new tire and be done with it.
stuo
« Reply #3 on: August 03, 2019, 04:46:49 PM »
Has anybody tried that balancer/sealant goop that looks like a miracle product? Any downside to it? Does it mess up the inside of the rim? The Youtube video is almost unbelievable: multiple nails, then two drill holes and it still doesn't go flat!
2009 GV 250
Biglee
« Reply #4 on: August 04, 2019, 12:03:55 AM »
Changed my rear tyre on Oct first 2017 got a screw in it next day put a tyre plug in it it lasted the life of the tyre that was on a cbf 1000
« Reply #5 on: August 04, 2019, 12:17:46 AM »
Car and the used to be new Michelin on the bike caught screws early on and have sticky rope plugs. Now the car with Kumhos started a slow leak after a couple of months so I re-plugged it and it is holding well. Intend to leave it until tire replacement. Also have a rope plug in lawnmower tire.
« Reply #6 on: August 04, 2019, 03:41:08 AM »
Use Shell SuperNitro in your lawnmower and tires rarely touch the ground.
« Last Edit: August 04, 2019, 11:37:07 AM by Stig »
« Reply #7 on: August 04, 2019, 10:01:39 AM »
 ;D
stuo
« Reply #8 on: August 04, 2019, 05:37:01 PM »
I'll be sure to wear my combat boots when walking on your lawn, Karl.
2009 GV 250
« Reply #9 on: August 04, 2019, 06:39:34 PM »
