Author Topic: Starting issues  (Read 505 times)
Biglee
Starting issues
« on: August 03, 2019, 06:13:49 PM »
Hi all need some help  so I put the key  in turn dash  lights up pull the left hand  brake on  then nothing  happens  so release left brake and pull the right ha d brake on  then push the start button then it starts but won't t start pulling the left brake anyone got any ideas  thanks
big blue
Re: Starting issues
« Reply #1 on: August 03, 2019, 07:58:49 PM »
When you pull the left brake lever does the brake light come on? Could be the switch on that side is bad or wires are loose or pulled out.
Biglee
Re: Starting issues
« Reply #2 on: August 04, 2019, 12:01:17 AM »
Not checked if the brake light comes on but will where is the switch located  thanks
Re: Starting issues
« Reply #3 on: August 04, 2019, 12:14:52 AM »
If this is a scooter...it is behind the not working brake lever. Right at/near the pivot point of lever. . Black plastic part usually. ..only a few $ if typical. On bikes it's in the open, scoots- inside the plastic panel.
Sometimes electrical contact spray will get it working if corroded.
« Last Edit: August 04, 2019, 11:38:54 AM by Stig »
mousejunks
Re: Starting issues
« Reply #4 on: August 04, 2019, 02:53:58 AM »
It is a common issue. The brake light switch burns out. The main symptom is that the brake light doesn't work when squeezing the brake lever. The switch is located near the brake lever pivot and looks like a black plastic block with a small button. You can soak it with contact cleaner then WD40 and see if it helps.
FYI the issue has been fixed on the 350i model. The switch is now covered in a rubber boot for waterproofing and the brake lights are LED to reduce current load and burnout.
« Last Edit: August 04, 2019, 03:12:56 AM by mousejunks »
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Biglee
Re: Starting issues
« Reply #5 on: August 04, 2019, 08:57:20 AM »
The ls for the help buys
