Author Topic: KYMCO like 200 keeps dying  (Read 17844 times)
Re: KYMCO like 200 keeps dying
« Reply #105 on: March 08, 2020, 02:03:03 PM »
You get 5 (=as in 5.0)? That means your resistance check  of 16.4 ohms is REALLY 11.4 ohms which is in the normal range. You still have a fuel delivery problem.
Causes:
1. System volts below 10.5 when cranking to start.
2. Low fuel pump output/pressure
3. Bad gas or diesel in tank.
4. Too much time on this forum has ruined you!
Sorry Karl,
I didn't imagine a multimeter being that far off calibration. ...so assumed he meant  .5  ,   not 5.0
Hope he clarifies for us.
If he had a meter reading 5 in self test -- probably should toss it - yes?
« Last Edit: March 08, 2020, 02:20:13 PM by Stig »
« Reply #106 on: March 08, 2020, 06:00:20 PM »
Could be a problem with test leads. Could be an old Simpson 260 with zero adjust. Could be .5 ohms. Who knows?
whiskers626
« Reply #107 on: March 09, 2020, 01:12:07 PM »
I’m gonna go today and buy a new voltage meter, I’m thinking my old one has some issues,
Question I noticed on my injector threre is a small tear in the print would that cause a problem not a big tear but it’s just nicked
whiskers626
« Reply #108 on: March 09, 2020, 01:15:23 PM »
The fuel pump seems to be working fine, I took the hose off the injector and turn the key on so I could get the last little bit of gas out and it seemed to be pumping pretty good, I need to find a scooter diagnostic tool ugh
« Reply #109 on: March 09, 2020, 03:21:51 PM »
"....tear in the print" ??
POINT?....the spray tip? You lost me here.
The fuel line?
And, yes a healthy multimeter to read that injector again would give us some good info!
« Reply #110 on: March 10, 2020, 12:23:55 AM »
Yeah, me, too! Whisker, what is "print" in relation to injector? You gotta use terms we understand or define the terms you use.
JJJoseph
  • Kymco Sento
« Reply #111 on: March 10, 2020, 08:10:58 AM »
It's about time somebody woke up to this fundamental tool that nobody here has ever heard of!
whiskers626
« Reply #112 on: March 11, 2020, 09:35:11 AM »
Sorry not point but O RING, not sure what happen, the auto correct on my phone I guess
« Reply #113 on: March 11, 2020, 10:33:31 AM »
OK, thanks.
To review :
1) continues to start & run for few seconds only on starter fluid spray?
2) obtaining another multimeter & will test ohms reading when:
## touching its 2 probes together
## touching injector
Small nick in O-ring should be OK.
Would be heck trying to find replacement.
whiskers626
« Reply #114 on: March 12, 2020, 10:26:25 AM »
Ok new meter readings below
Touching probes together 4.3
Touching probes on injector 16.5
« Reply #115 on: March 12, 2020, 01:03:24 PM »
Many of us live to solve problems on these scoots! Nothing is more satisfying than to hear a guy or gals scoot is now back running better than ever! But each one with a problem has to meet us half way with information. Makes no difference who comes up with the solution. The main idea is that the problem is solved and you are back in the saddle, again!
New meter readings? New meter or new readings on original meter?
OK, your injector is 12.2 ohms, good to go. If it sprays consistently into a can during start sequence then you have either an air or compression problem.
But, since it will fire and run while you spray into inlet something flammable that gets back to a fuel problem or fuel delivery problem.
Something is missing in the information....
« Last Edit: March 12, 2020, 02:12:36 PM by CROSSBOLT »
« Reply #116 on: March 12, 2020, 11:32:10 PM »
I'm having trouble with the readings whiskers is reporting.
My concern is with such a huge "test reading" of 4.5 ohms (or previous 5.0 ohms).
I'm no electrical expert - so I spoke today with 3 private electrical service shops in town.
Each said pretty much the same thing, to wit:
"When touching probes together on a digital multimeter it should read 0 or very near 0" (0.3, 0.6, 0.4, etc.)
And: "Readings which are not zero, or very near zero," (such as whisker's 4.5>5.0 ohms) - "is indicative of a faulty tool or bad battery in the tool."
There is usually no adjustment on a digital multimeter to "0" the meter before starting.
If he is using an analog meter (pointer with scale) these must be "zero'd" before taking the reading of the injector. There is a small screw or knob to perform this zero-ing.
Photos or a video of whiskers taking his reading with his meter would sure be helpful.
If our equipment is faulty - or the testing is faulty - we've moved no closer to a fix, nor have we ruled anything out.
« Last Edit: March 12, 2020, 11:34:58 PM by Stig »
JJJoseph
  • Kymco Sento
« Reply #117 on: March 13, 2020, 01:42:22 AM »
O-rings are not a problem - just go to the O-ring store, there's usually one in any decent-sized town.
« Reply #118 on: March 13, 2020, 11:34:59 AM »
Right on all points, as usual. The issue with the 4.5 or 5 ohms is probably contact resistance INSIDE the meter. I have had to open up and goober the range switch and fuse clips on a cheapo meter here. Even had to do that on a Simpson 260  I have had since 1960! Go figure! Contact cleaner and lube...
whiskers626
« Reply #119 on: March 23, 2020, 06:20:36 PM »
Ok all, I’ve read back through all pages and redid all the test and everything checks out and still nothing. I have decided it is some type of fuel thing. When I spray starter fluid in the air breather it will run as long as I keep spraying a little in there. So I don’t know what to do at this point. I’ve been looking for a rental diagnostic tool but my searches are coming up short.
Any other ideas?
