In case you have to investigate and/or replace the LIKE's fuel pump:The stock LIKE200i fuel pump has "no serviceable parts" according to my manual.
The 0 ring is supposed to be replaced each time you remove the pump from the tank.
No one sells the giant 0 ring - it is attached to the new $+200 pump assembly.
The pump must be eased out of the tank with some effort (like a cork in a bottle) and I returned it with a bit of silicone lube all around. Taking the measurements of the stock pump and after a phone contact with the tech. - I purchased a replacement 30mm HIGHFLOW pump. (ebay advert. said it would fit a Suzuki motorcycle)
It's been working great in my 2012 LIKE200i for 7 years.KYMCO holder accepts a pump this size.... 30mm X 70mm
https://www.highflowfuel.com/i-28316344-quantum-intank-efi-fuel-pump-for-hyosung-ms3-250-scooter-2010-2020-replaces-hyosung-15100hp8800.htmlBasically 'plug-and-play' Take a photo if need be to get all connections back in proper places.
Match the wires and hoses, place in the stock KYMCO pump holder and reinsert it back into the tank. Bolt it up and check for leaks.
All kinds of pumps are available - I paid a bit more for the HighFlow as I don't want to repeat this procedure!
Stock pump is in this metal and plastic holder.....which you will re-use!
New HighFlow pump installed in holder.
(This has been edited following loss of photos in orig. post)
