Author Topic: Noise coming from the front tire already? - PROBLEM SOLVED  (Read 29357 times)
Rianna
Re: Noise coming from the front tire already?
« Reply #195 on: October 07, 2010, 09:05:48 PM »
What?
omfgdotcodotuk
  • fookin quick gilera ice 50/70cc malossified ish
« Reply #196 on: October 07, 2010, 09:10:26 PM »
i was refaring to the marine salt water resistant properties of the grease you pictured ria,i have a marine outboard that sure could use some of that grease,cant get it over here,well not pennzoil anyways darn it :)
« Last Edit: October 07, 2010, 09:16:35 PM by omfgdotcodotuk »
Never ride faster than your guardian angel can fly ;)
Rianna
« Reply #197 on: October 07, 2010, 09:22:42 PM »
OH, sorry, omfg. I thought Pennzoil was everywhere since it's been around forever. So that grease isn't good for what I need?
omfgdotcodotuk
« Reply #198 on: October 07, 2010, 09:28:34 PM »
Sorry!!.sorry for what?,yeah hun the grease is good,its gonna be great on bearings and such,just wish i could get it over here darnnnnnnn :)
Rianna
« Reply #199 on: October 07, 2010, 09:40:49 PM »
So it's good for bearings AND the other stuff art mentioned a few posts back?
Yeah, you should've shipped me your front end after you fixed yer bearings and I would've gladly shipped you a boatload of grease. LOL. :D
Rianna
« Reply #200 on: October 08, 2010, 12:08:39 AM »
With caliper removed. Its bearing,axle or speedo cable. They do not lube the axle well on alot of these and the speedo cable is conected at the hub. It would be free to inspect and clean these and about 2 cent worth of grease to lube  :D Try that first.
Can anybody tell me if this grease is good for all these things art said to try first or not? Just for bearings or use it to grease everything?? Thanks.  :)
art
« Reply #201 on: October 08, 2010, 07:55:35 PM »
  Marine grease is really good,used it on all my dirt bike.
Rianna
« Reply #202 on: October 08, 2010, 11:21:49 PM »
Thanks, art. I had only 2 choices. It was either going to be this one or Walmart's SuperTech brand. Glad it will work.  :)
« Reply #203 on: October 08, 2010, 11:45:47 PM »
..you need to get t' ridin' that guilty!!!
Rianna
« Reply #204 on: October 08, 2010, 11:52:57 PM »
Don't I wish! I tried again today, but I can't get that Axle nut off. Took it out today and didn't make it to the end of the road. That front wheel is crazy now. It's parked...indefinitely...again.  >:(
codger78
« Reply #205 on: October 29, 2010, 08:38:40 PM »
Is it possible  the noise could have been coming from the speedometer/odometer cable or gearing in the wheel area ??? ???
borrowed dust
Rianna
« Reply #206 on: October 29, 2010, 11:25:54 PM »
Being that I don't have the correct the speedo box on mine it wouldn't surprise me. I noticed that the small end of the axle rod was on the wrong side of the wheel when I compared it to the diagram on stadiumyamaha so I started checking the order of each piece to make sure I put it all back on the correct way. First I noticed that the collar or spacer was facing the wrong direction. Then when I got to the speedo I saw two washers or seals on the diagram that I didn't have. I studied over this for awhile wondering if the gear would work right without them before I realized that the whole thing was for a different model scooter. I suppose the axle rod may function properly in either direction, but if the speedo gear does not line up flush the way it should this could probably cause a bit of a racket if it gets caught up.
But TechGuy hooked me up with a way to test it out so I'll find out for sure tomorrow. We've got some trees down in the yards down here and I can't get it to the road. They're supposed to finish cleaning the mess tomorrow. If they don't I might have to pick up some branches and roll some logs out of the way myself, lol. I'll test it with the cable disconnected first. Then with it connected. If I still get noise I'll try it with the gear out and just use the box as a spacer. At least I would be able to ride until I get it replaced. Thanks, codger78!
« Last Edit: October 29, 2010, 11:34:57 PM by Rianna »
codger78
« Reply #207 on: October 30, 2010, 03:07:59 PM »
Good luck Rianna... ;D ;D ;D
borrowed dust
« Reply #208 on: October 31, 2010, 01:58:32 AM »
so rianna whats the scoop on your scoot is it up to 100 % yet is it drive able.what kind of work needs to be done.
« Reply #209 on: November 03, 2010, 01:59:14 AM »
...where'd she go....
