Author Topic: Starter motor  (Read 1174 times)
Ajayprasad
Starter motor
« on: August 05, 2019, 05:11:53 PM »
I can not find anything about removing the starter on scooters that resemble the Like. I looked in the service and owner's manual , the descriptions are vague at best. I know where it is, I just can't find anything about the best way to get it out. Any advice and/or pictures would be much appreciated.
Ajayprasad
Re: Starter motor
« Reply #1 on: August 05, 2019, 10:50:28 PM »
I was graciously provided with pictures. Now if I could only find pictures of the air, throttle, and idle screws   ::)
245luigi
  • Boston, MA
Re: Starter motor
« Reply #2 on: August 05, 2019, 11:53:26 PM »
https://photobucket.com/gallery/https://s38.photobucket.com/user/zerosk8erfreak15/media/WP_20140606_012.jpg.html
Bettingandlosing posted this pic, the idle speed screw (adjust idle rpm) is the screw that is not circled, the idle air screw is the circled one (I don't actually remember if its a fuel or air screw but since its downstream from the slide it may be a fuel screw). From the factory there is a brass cap glued over it so you have to remove it. The screw is a "D" head so you either have to put a notch in it like in the photo to take it out with a flat head or get the right socket.
See here
http://www.kymcoforum.com/index.php?topic=11962.0
There are no other adjustment screws for mixture on the stock carb
« Last Edit: August 06, 2019, 09:43:43 PM by 245luigi »
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
