Author Topic: Vibrations front wheel  (Read 721 times)
sotsma
« on: August 15, 2019, 06:50:52 PM »
Hi all
Today I decided to change the bearings of the front wheel, and I noticed that there is a gap between the bearing and the axle. I made a video of this. Does anyone know if this is normal?
https://drive.google.com/open?id=15w45twTUDA4u6bkKHJK2EP4CMMwjaGoA
Thanks in advance
« Last Edit: August 15, 2019, 07:53:51 PM by sotsma »
Downtown 300I ABS '10
Cheetah 50 '09
XT 250 '93
Re: Vibrations front wheel
« Reply #1 on: August 15, 2019, 07:28:45 PM »
Video not working... pictures look good. What we supposed to see?
sotsma
« Reply #2 on: August 15, 2019, 07:59:48 PM »
I tested the link with 2 different pcs and looks fine !!??
What can you recommend?
Cheetah 50 '09
XT 250 '93
« Reply #3 on: August 15, 2019, 08:59:11 PM »
I am using a Samsung tablet and video won't play...
As far as fit to axle, it should slide on the axle shaft with NO "play", no space, no gap.. Wrong bearing if there is. I think it should be a 6204 2RS on each side....
« Last Edit: August 15, 2019, 09:42:51 PM by CROSSBOLT »
sotsma
« Reply #4 on: August 15, 2019, 10:06:24 PM »
The bearings sould be the 6002LU = Sealed Ball Bearing 15x32x9 mm
 The 6204 are 20x47x14mm !!! none even close.
« Last Edit: August 15, 2019, 10:27:34 PM by sotsma »
Cheetah 50 '09
XT 250 '93
« Reply #5 on: August 15, 2019, 10:34:25 PM »
I see your video.
The axle/bearing fit seems to show too much play.
« Reply #6 on: August 16, 2019, 12:23:20 AM »
Oops! Thank you for setting that straight! I'm old! Come to think I saw that 6002 in one of the pictures! And Stig saw the gap in his video. So what ain't right! Shaft not right?
