Author Topic: Kymco 500ri no compression in cylinder  (Read 5296 times)
ggraven
Re: Kymco 500ri no compression in cylinder
« Reply #45 on: September 13, 2019, 02:17:37 PM »
Thanks 2cents for the info.
scooterfan
« Reply #46 on: September 14, 2019, 06:02:49 AM »
No problem. After some reading I started thinking these models might not be worth more than 2cents anyway.
« Reply #47 on: September 14, 2019, 11:22:56 AM »
It's a puzzle...some have good experiences with the 500. Others have no luck.
I sure wouldn't buy a non running one! Chances are not good it will be an easy fix.
ggraven
« Reply #48 on: October 07, 2019, 08:27:29 PM »
Well I finally took the Kymco 500 to a dealer and it turns out that the cams in it were almost flat and fuel was going into the oil, so they are installing new valves, cam shafts and new piston rings. oil change. Parts are 450.00 and labor 500.00. But I am still ahead on the deal I will have 1200.00 in it all said and done.
Just wanted to give some info for maybe someone else to help. They told me it needs 185 psi of compression to get it started.
Thanks for time gentlemen!
« Reply #49 on: October 07, 2019, 09:21:53 PM »
Get the cams tested for hardness BEFORE installation!! The hardness/heat treatment was
The problem with all cam failures. Don't let them talk you out of it!
KymcoRockr
« Reply #50 on: December 06, 2019, 07:56:32 PM »
I'm guessing you think they'll do that for free, right? Most shops don't do this, and would have to send it out.
AK550
Yager 200
« Reply #51 on: December 07, 2019, 12:05:49 PM »
Probably you will have to pay for a lab to test them. Either way, you are gonna pay. The only difference is the engine will probably last longer than both of us if the cams are of proper hardness.
MJR
« Reply #52 on: December 07, 2019, 07:02:17 PM »
Ask for the old parts back. I'd like to see photos of them.
Gas in the oil can cause low compression by washing out oil in the piston rings. 185 psi compression is the spec but I'd think it could run on less. Compression is checked with the throttle wide open.
I had a 2016 with under 15K miles on it that had a major loss in power, I measured at 140 psi with the throttle closed and turns out with the throttle wide open it measured around 210 psi. The dealer tried several things and ended up putting a muffler on it claiming a broken baffle inside. I haven't had a chance to ride it and see if it's fixed because the owner doesn't have current registration on it.
Curious as to why this post isn't in the Xciting 500 sub forum?
« Last Edit: December 07, 2019, 07:17:51 PM by MJR »
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
