Author Topic: 2007 Agility 125 tail light fixture help needed  (Read 1309 times)
Narax
« on: August 28, 2019, 11:14:30 PM »
Hello all new to the forum and I would like to ask a question.  I have a 2007 Agility 125 used pretty lightly.  While the previous owner took very good care of it the owner before him dropped it multiple times.  Minor cosmetic damage entirely except for one thing.  The fixture for the rear turn signal light is loose and it wiggles around.  In my state it is required to do inspections and they are pretty picky, something like that won't pass.  If I could get some information about how the fixture is connected to the back that would be greatly appreciated.
« Last Edit: August 28, 2019, 11:19:40 PM by Narax »
118118
Re: 2007 Agility 125 tail light fixture help needed
« Reply #1 on: August 29, 2019, 01:46:43 PM »
Hi,
Are the 'turn signal' lights on your scooter on the sides as individual units, or all part of the rear light?
Narax
« Reply #2 on: August 29, 2019, 06:34:28 PM »
The rear tail indicator lights are a seperate fixture from the break light.
118118
« Reply #3 on: August 29, 2019, 07:11:58 PM »
I assume then it just bolts through the rear light plastic housing. Either the nut has come loose or the plastic has broken.
Narax
« Reply #4 on: August 29, 2019, 07:30:05 PM »
That is what I thought.  I wasn't too sure how to access it though.  I don't want to start unscrewing stuff that I don't need to unscrew.  To get in there do I need to unbolt the two coloured plastic panels on either side?
Ive attached some images of the problematic signal light.  As well as an embarrassingly dirty scooter...
Narax
« Reply #5 on: September 06, 2019, 11:51:17 PM »
How exactly do you remove that pannel in the rear to tighten the bolt.  The bolt is pretty loose I took out the seat bucket and saw it but had no idea how to get to it.
