Author Topic: Vitality 2 stroke swapped into Super 8 4 Stroke Scooter  (Read 1499 times)
AylmerFreerider
« on: September 01, 2019, 03:01:05 AM »
I am looking at picking up a 2009 Vitality 2 stroke for parts.
Wondering if I could swap out the 4 stroke in my 2015 Super 8 4T.
It seem that they have a similar drive belt (737mm vs 743mm but it seems these are interchangeable based on looking up part numbers)
Would I also have to swap out the gears as well to match up?
Thanks
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
AylmerFreerider
Re: Vitality 2 stroke swapped into Super 8 4 Stroke Scooter
« Reply #1 on: September 03, 2019, 04:18:03 PM »
wow totally thought someone would have an opinion on this.
Bueller,  Bueller,  Bueller.....
2015 Super 8 50R
72cc BBK
big blue
« Reply #2 on: September 03, 2019, 06:04:00 PM »
Probably no replies due to not having a clue. Since your Super 8 is the new smaller wheel version it COULD fit so do some measurements and go for it! Some of the 50cc tuners on here may have more expertise on this. Obviously a 2T engine will have more punch than your 4T engine.
AylmerFreerider
« Reply #3 on: September 04, 2019, 03:14:23 PM »
So after taking the Vitality plastic off to get a better view it won't go straight swap.  The mounts are different so I guess fix up the vitality and sell it.
Will probably have to find a 2T agility for this.
Still going to take the gears from this one for the Super 8 though.  I am pretty sure there is a 10% increase in there.
2015 Super 8 50R
72cc BBK
JJJoseph
  • Kymco Sento
« Reply #4 on: September 07, 2019, 03:42:16 AM »
As a retired 2T tuner, this sounds like totally nuts!  Much easier, and WAY cheaper, to sell the tiddler and buy something bigger.
AylmerFreerider
« Reply #5 on: September 07, 2019, 03:58:50 AM »
has  more to do with the fact I don't want to get a  motorcycle license.  I can drive a "50cc" scooter with my regular drivers license.  The  motorcycle costs an extra $80 a year.
The gears will make all the difference on  my 4T.  its the last restriction plus I can get the Tecni-Gas R type exhaust for it for under $150 Canadian as well
2015 Super 8 50R
72cc BBK
« Reply #6 on: September 07, 2019, 11:00:30 AM »
I was under the impression that aftermarket pipes had prretty much no effect, save for noise increase, on a 4 stroke?
AylmerFreerider
« Reply #7 on: September 07, 2019, 11:15:47 PM »
You have to upjet for them so there must be something there.
I noticed a difference with i went from stock to 1 step up.  The new exhaust will be 2 steps up
2015 Super 8 50R
72cc BBK
Bi6foot666
« Reply #8 on: September 29, 2019, 02:47:26 AM »
I have a super 8 150. The 150s and 125s are top mounted. A 50cc four stroke typically os bottom mounted. But the 2 strokes are not. They are top mounted. Its possible. But youd have to swap out the whole thing. Including gearbox. But if u can find a whole super 9 motor thatll be dope.
Sent from my LM-X220 using Tapatalk
Bi6foot666
« Reply #9 on: September 29, 2019, 02:49:12 AM »
The super 9 gears were great but then they made the 2 stroke super 8 and they were not as good.
JJJoseph
  • Kymco Sento
« Reply #10 on: October 02, 2019, 04:50:34 AM »
The  motorcycle [licence] costs an extra $80 a year.
LOL! Swapping engines is going to cost you way more than $80/year extra!  A 2-stroke will likely last not more than 15,000km, then you'll have to buy a new engine.  You might get 30,000km out of a 4-stroke.  Moving up to a bigger (longer lasting) engine engine might be a whole lot cheaper in the long run.
AylmerFreerider
« Reply #11 on: October 02, 2019, 06:36:23 PM »
Well considering I just picked up a used Vitality for $150 and I would still have the old 4 stroke motor as well I would say I am good for the next 10 years at least.  The $80 I save a year will let me buy another used scooter or three I could scavenge from.  Sounds like I am in the words of Charlie Sheen "#winning" here.
2015 Super 8 50R
72cc BBK
