Author Topic: 2019 Kymco Like 150i with Noodoe Check Engine Light  (Read 3364 times)
cathyco6
Re: 2019 Kymco Like 150i with Noodoe Check Engine Light
« Reply #15 on: July 07, 2020, 08:07:04 PM »
I just bought a 2020 and ABS rear speed sensor went as well.  Now it is stalling while driving! It happened twice and I put only 70 miles on it!
« Reply #16 on: July 07, 2020, 08:12:39 PM »
Back to the dealer I hope!?
Refuse to take it until issue found and fixed.
lecollazo
« Reply #17 on: August 26, 2020, 10:18:20 PM »
I had issues with my Like 150 cutting out and dies.  It turned out to be a loose wire to the fuel injector.  Take it to the dealer and have them read the codes in the ECU.  The only problem is that it's often hard to find an intermittent problem.  In my case reading the codes didn't help.  The tech found the loose wire.
I'd ride it and see if the problem happens again.
Had the same issue. After 42 MPH it start cutting out and dies. Take it to the dealer and it was repaired and returned to me. After taking it to the road, immediately it repeat the problem. The scooter goes back to the shop and finally the mechanic explain it was a cable on the fuel injector. They ordered.
Will update when scooter is repaired.
« Reply #18 on: August 27, 2020, 11:39:50 AM »
Good find for your mechanic!
Hope that fixes it.
Cyclepedia.com technician suggested that injector wire might be the problem with certain Like200i issues we've seen here.
Kind of hard to do much more than a visual check for most of us.
And, welcome to the forum!
Please do let us know....
