Author Topic: More RPM after Gear Upgrade  (Read 599 times)
AylmerFreerider
« on: September 08, 2019, 11:10:26 PM »
Hey all looking for some advice on this now.  I have upgraded the gears now.  It had a 14/54 and I was able to pick up a Vitality 50 2T and swap the gears from it.  They are 16/53.
This works out to a 13% increase or remarkably 13kph but my scooter seems to be not able to get past 7000 RPM and still stuck at 68kph.  So I am going to try lighter rollers and see how that works.  Before I was getting 68kph at 7800RPM
Set up is as follows
72cc BBK
92 main jet
1000 RPM Contra Spring
6.5gr rollers (just installed 6.2 to see how it goes, I also marked the variator with a marker to see how high the belt will go.)
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
JJJoseph
  • Kymco Sento
Re: More RPM after Gear Upgrade
« Reply #1 on: September 18, 2019, 01:59:58 AM »
Rollers don't affect top speed, only acceleration.  You're on the right track with the gears, but now you need more hp to get a higher top speed.  You're making the scooter work harder. Usual remedy is a BBK.  With 100cc and your gears, and nothing else, you should be able to make 80km/hr. There is no substitute for cubic centimeters!
« Last Edit: September 18, 2019, 02:03:19 AM by JJJoseph »
AylmerFreerider
« Reply #2 on: September 23, 2019, 12:21:59 AM »
I have the 72cc BBK installed.  I could upgrade one pipe (from technigass Silent Sport to the Next R) and a bigger jet.  I am getting more power since upgrading my air filter.  Holding 72 now but hoping to hold 75 as a goal.. I wasn't looking for a huge boost just enough to be safe on the 70km/h roads.
2015 Super 8 50R
72cc BBK
