Author Topic: Gear shaft?  (Read 1675 times)
Ajayprasad
Gear shaft?
« on: September 09, 2019, 03:42:10 AM »
So I did this...
I'm trying to 1) get the nut off. I guess I have to repeat PB buster and heat repeatedly. I acquired a torque wrench but the instructions advise not to loosen fasteners. or 2) I'm going to cut the rest of it off. There in lies the question, going off of
https://www.oemmotorparts.com/oem5.asp?M=Kymco&T=LIKE%2050&Y=_&L=KYMCO_LIKE%2050&O=Transmission&F=KYMCO_LIKE%2050_Transmission&L2=KYMCO_LIKE%2050_Transmission
Is it the final drive 23431 or the shaft drive 23411? I just want to find the part because I'll have to wait forever  :'(
Thank you
Ajayprasad
Re: Gear shaft?
« Reply #1 on: September 09, 2019, 03:55:31 AM »
big blue
Re: Gear shaft?
« Reply #2 on: September 10, 2019, 04:20:51 PM »
I believe that the shaft that takes drive from the clutch is 23431 the other shaft has the splines for the wheel mounting.
JJJoseph
  • Kymco Sento
Re: Gear shaft?
« Reply #3 on: October 04, 2019, 04:12:54 AM »
Don't cut or drill or heat anything!  The nut comes off easily with the right socket.
Ajayprasad
Re: Gear shaft?
« Reply #4 on: October 04, 2019, 08:44:27 AM »
Too late now. It's already been replaced. That was my first method. I could very well be wrong but it was not coming off with the correct socket. It generated so much torque the contra spring expanded.
