Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
Death by a 1000 cuts...Front Fender Broke
Topic: Death by a 1000 cuts...Front Fender Broke (Read 809 times)
mrbios
2005 Kymco Grandvista 250cc
Just crusing along on my 2005 GV250
September 11, 2019, 07:23:39 AM »
I changed the headlight to an LED and since that time I noticed a clunking noise coming from the front fairing. Went in a second time to aim the head light. Same noise. Today I was taking the cover off and saw the front fender had broken.
PaulC
Re: Death by a 1000 cuts...Front Fender Broke
September 11, 2019, 08:08:31 AM »
Two very large washers required?
mrbios
September 11, 2019, 09:15:28 AM »
Quote from: Neil955i on September 11, 2019, 08:08:31 AM
Yes and already installed. The screws were #3 Phillips and I used my hand impact driver to break them free which took many many hits with a hammer then the top screw for some reason was much longer than the bottom screw and it took several minutes of hard twisting with the hand Impact Tool after I got it Loose because I think it had Loctite on it and probably had never been removed after I put the washers in place I dabbed a little bit of epoxy just to hold them there and all is good now.
Last Edit: September 11, 2019, 09:36:53 AM by mrbios
PaulC
Reply #3 on:
September 11, 2019, 12:27:19 PM »
Glad you're all sorted, nice bodge!
Back
