Author Topic: Stuck on final drive shaft replacement  (Read 2050 times)
Ajayprasad
« on: September 26, 2019, 09:54:10 AM »
I am attempting to get into the gearbox so I can change the drive shaft but I don't know how to open it. I have the service manual and it's vague. What I have is different from all the how to videos and text that I can find on the subject. Inferior to the crankshaft is a part I've never seen before and have no idea how to remove. Anyone know what that is and how to open up this type of transmission? Much appreciated.
I can't seem to add any pictures. Hopefully someone knows what I'm referring to, it looks like a long case minarelli and the dimensions seem correct. The left crankcase has three bolts by the drive pulley and it does not appear to support a panel, so I think the right side must be removed. The right side has the part that attaches to the brake cable and then is the "hammer drive anchor?"
245luigi
  • Boston, MA
Re: Stuck on final drive shaft replacement
« Reply #1 on: September 28, 2019, 07:13:03 PM »
Please add pics, no idea what you are talking about.
Upload them to imgur then post the link here
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
245luigi
  • Boston, MA
« Reply #2 on: September 28, 2019, 07:34:18 PM »
Remove these bolts to access final drive
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Ajayprasad
« Reply #3 on: September 29, 2019, 12:09:40 AM »
https://m.imgur.com/a/uVKpT7C
Thanks, I didn’t know how to get around the size restriction for the photos. So the case is different then diagrammed and I think I need to pry it off at this point.
245luigi
  • Boston, MA
« Reply #4 on: October 03, 2019, 03:08:41 PM »
It looks like all you need to do at this point is just separate the final drive and cvt case
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
JJJoseph
  • Kymco Sento
« Reply #5 on: October 04, 2019, 04:06:02 AM »
Yikes! Don't "pry" anything until you're sure of what's going to happen.  The case comes apart easily, with almost no effort, when you remove the bolts.  It's almost a no-brainer.
Ajayprasad
« Reply #6 on: October 04, 2019, 08:45:27 AM »
I am pleased to inform that I got everything replaced with no damage. It just took a little bit of elbow grease.
