Author Topic: Quick LIKE200i oil change  (Read 755 times)
« on: October 02, 2019, 03:45:33 PM »
Pull the plug -- go do some errands while it drains. Replace the washer and cap it up - add less than a Qt. of new oil.
...and, "Bob's your father's brother!"
Kymco specifies every 1200 miles for an oil change.
I usually do them at 600 > 800 miles......
Using up the gallon of Suzuki oil left over from the Burgman 400, sold 2 yrs ago. (at less than a Qt. it takes awhile!)
I like these teflon coated washers at each oil change. (made for Toyotas - ebay - bag of them for a couple $)
17mm 6-point socket.
While I'm down there - it's a good time to drain this drain tube.
With my frequent oil changes I only open the big cap with the spring & screen thing once a year or so. Never find anything in there! Do not overtighten it!
BTW - local county police garage uses the old oil in their furnace for winter heat!
« Last Edit: October 02, 2019, 03:48:43 PM by Stig »
DanH
  • San Diego, CA
Re: Quick LIKE200i oil change
« Reply #1 on: October 02, 2019, 04:23:53 PM »
Thanks for posting this "how to." I will use it for sure. Any chance you can display a graphic of the entry you made for an oil change in your owner's manual. I don't want to invalidate my warranty for an admin error.
monkeybongos
  • Tampa, Fl
« Reply #2 on: October 02, 2019, 04:36:45 PM »
Has anyone put a magnetic drain plug on their bike?  Seems like a worthwhile investment.
2016 Wolf V-50 (sold)
« Reply #3 on: October 02, 2019, 05:50:49 PM »
It just reads,
"10/2/2019  15,038 engine oil, Suzuki 4-cycle 'Performance ' 10W/40"
Come winter months I'll be using 5W/40.
If buying new oil, do keep the receipt, and write date/mileage you put it in.
Don't overfill, don't overtighten, and don't screw in the dipstick to check for proper level - and you can't go wrong I don't think.
Are you using the break-in procedures per the owner's manual? Some say to ignore same - I always followed the manual. . 7 seasons on, my LIKE200iLX uses no oil.
« Last Edit: October 02, 2019, 05:59:37 PM by Stig »
scootertherapy
« Reply #4 on: October 06, 2019, 11:03:50 PM »
Thanks agains Stig.   I use this to track service on all my vehicles. https://www.mileagetracker.org/index.php
