Author Topic: Agility 125 - no life with new battery  (Read 2963 times)
Viper254
  • Moped Pirate
Re: Agility 125 - no life with new battery
« Reply #15 on: October 30, 2019, 08:54:21 AM »
That's a bit bizarre as I thought they were on the switched live circuit as well.
It sounds like it's going to be a case of going backwards through your circuit with a multimeter. It may be worth starting at the brake light switch and working back from there to find where the connection isn't being made, and hopefully this will lead you to the horn - or you could do vice versa :)
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
TwowheelsV
« Reply #16 on: October 30, 2019, 09:38:20 PM »
Thanks Viper, I'll let you know what I find.
TwowheelsV
« Reply #17 on: November 05, 2019, 07:00:11 PM »
Whelp, the previous owner decided to remove the switch from the brakes so you don't need to pull them to start it. Also, I found that the starter relay is bad.
Turns out that Amazon has quite a few parts available through Prime! Should have her running this week.
