Hi!
I've been commuting with my new Like 150i, and have loved it. I'm at about 2K miles, and completed all of the first preventative maintenance on the bike already (oil changes, valve clearance... etc.)
The problem is that last week the "CLEP" (check engine lamp) went on, and there is a severe lack of resources available for self-diagnosis.
I see posts about diagnosing the Like 200 and others, but none for 150i. Also, there is no subforum for the 150i??
There is a fuel injection failure code chart in the service manual I got off Cyclepedia, but no way to figure out which failure code is causing the light to turn on, as far as I can tell.
Is there a computer self-diagnosis tool I can buy? I see the part number 3620A-LEB2-E00 floating around, but I don't see a place to buy it. Or is there a way that the CLEP will beep to tell me the failure code, and if so, is there a chart that tells me which beep sequence equals what failure code?
Is the only way to diagnose this to bring it to a dealer? Or are there common problems that come up with the 150i that I can check?
Thank you! I appreciate any help people can give me.
