Ha! I was scratching my head too. I eliminated all the smog. Took out the carbin canister and all attached(you can get to the spark plug now
![Grin ;D](https://www.kymcoforum.com/Smileys/default/grin.gif)
) You do need to cap the inlet on the intake. It was a vent that seemed to have no perpose. Like the rest of the emissions.Not a clue what it does
![Huh ???](https://www.kymcoforum.com/Smileys/default/huh.gif)
The other hose coming out the head ran back to the airbox and t'd into the the vac lines,just a rebreather so by passed that also. Not sure what to do with the large end yet.(just caped it) It does have a positive flow And can spit some fire out of it if the motor misses
![Shocked :o](https://www.kymcoforum.com/Smileys/default/shocked.gif)
but also seems to have no use except to vent unburnt fuel back to the airbox to re-cycle. Not sure if i should vant it with a check valve or eliminate it with a solid gasket at the mount.
At this point all runs good,no ill affects but no real gains in power either.
Sorry to hear about the bike,That sucks
