A couple of days ago I started another thread - mentioning a strange noise and slight vibration which I thought / hoping was coming from a worn wheel bearing. I thought the noise was coming from the front wheel bearings - so both bearings have been replaced with new ones. No improvement at all - the noise and slight vibration did not disappear.
Something I didn't mention at the other thread - the original clutch pads at my scooter got very thin and has been replaced with a 2nd hand clutch which came from a Chinese scooter. The 2nd hand clutch is still in good condition, has the same size, and matched the Kymco pulley assembly perfectly. The strange noise and slight vibration actually started immediately just after installation. Just before the 2nd hand clutch was installed there was no noise or vibration at all.
After a short initial ride the clutch has been removed again for inspection . Everything including the two clutch bearings seemed to be perfect - therefore I thought maybe by fluke some of the wheel bearings might be on it's way out.
It might make sense to have a look at the rear wheel bearings as well, but I started having a feeling the noise and slight vibration might have something to do with the 2nd hand clutch or CVT system. At the time when the worn clutch was removed I didn't have the correct size socket or spanner to remove the nut - so I took it to a local scooter shop. One of the mechanics clamped the pulley in a vertical position in a bench vice, and loosened the nut with a vice grip. I am not sure whether the pulley got bend or damaged while being clamped in the bench vice - so probable have no choice other than stripping the CVT assembly again.
For the time being I would appreciate any comments. Did anyone ever experience a similar problem ?
