Author Topic: Hi need your help, Super 8 2T from Montreal!  (Read 1573 times)
vermiselle
« on: November 02, 2019, 04:54:26 PM »
Hi,
I just buy kymco Super 8 2 Strokes 2011 with 8000km. All original, restriction removed (Variator and exhaust).
I didn't check if they change the main jet!?
The rollers on the original variator are finish, they have flat on 3 rollers (8.2g). For now i put 6.5g on the variator, only this one i have here... Acceleration little bit faster, but motor rpm is higher and it's longer to hit the 55km/h (my top speed)!
What is the best configuration with the stock motor (49cc) to have the better speed!?
I would like 70 km/h!
If i need to change the exhaust system i don't want one too noisy because the police check that here.... Can i stay with the original one!?
Did is it better to change the variator, modify the original air box and change the jet ....
Thank's!
« Last Edit: November 03, 2019, 08:01:42 PM by vermiselle »
AylmerFreerider
Re: Hi need your help, Super 8 from Montreal!
« Reply #1 on: November 03, 2019, 12:05:07 AM »
Is this a 4T(4 Stroke) or 2T(2 Stroke)?
Different things needed for different versions
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
vermiselle
Re: Hi need your help, Super 8 2T from Montreal!
« Reply #2 on: November 03, 2019, 08:01:04 PM »
It's a 2 strokes!
eamartin
« Reply #3 on: November 03, 2019, 08:11:35 PM »
G0 here: //www.kymcoforum.com/index.php?topic=11872.0
« Last Edit: November 03, 2019, 11:51:01 PM by Stig »
vermiselle
« Reply #4 on: November 22, 2019, 03:45:45 PM »
Thank you for the link, but I want to have the most performance with the least performance parts...
I will probably change the original variator for a Malossi or Polini, but the rest as original as possible!
I do not want to have an exhaust too noisy, because here the police do not tolerate!
That's why I want to keep the original exhaust as much as possible, unless there is a performance exhaust, with an unrestricted and original look !?
Thank's!
