Author Topic: DOWNTOWN 300I DIED ON ME  (Read 783 times)
douli911
« on: November 21, 2019, 06:08:02 AM »
HI GUYS MY KYMCO 300I I WAS RIDING ON FREEWAY AND NOTIVED BATTERY LIGHT HAD COME ON , I TURNED MY LIGHTS OFF THINKING IT MIGHT HELP THE LIGHT DID GO AWAY BUT FURTHER DOWN I WAS ALMOST HOME THE BIKE JUST DIED ON ME NO LIGHTS ON DASH NOTHING AT ALL COMPLETELY DEAD . ANY IDEAS IM VERY ANGREE ABOUT THIS
Re: DOWNTOWN 300I DIED ON ME
« Reply #1 on: November 21, 2019, 12:03:54 PM »
Get a battery charger and see if the battery will charge.  If it charges then see if it will run.  If it does then you probably have a bad alternator.  If the battery won't charge it's probably a bad battery.
douli911
« Reply #2 on: November 22, 2019, 01:21:24 AM »
thank you
will do
mousejunks
« Reply #3 on: November 22, 2019, 04:42:00 AM »
Battery is not charging. Here is a fix I wrote a while ago: http://www.kymcoforum.com/index.php?topic=24424.0
It is a common issue and Kymco has changed the charging system on the 350i to correct this.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #4 on: November 22, 2019, 03:47:05 PM »
Mouse, that was and is a great post. Technically correct and easy to follow! Is your ebay reg/rect still working? What is it, how much and didja change it without taking the rear bodywork off?
mousejunks
« Reply #5 on: November 23, 2019, 03:23:48 AM »
You only need to remove the seat bucket then unscrew 2 nuts to release the regulator.
The reg cost less than 30 USD and worked to 80,000km until my DT300 was an economical write-off.
« Reply #6 on: November 23, 2019, 04:02:20 PM »
That's great! Now which one on ebay?
MJR
« Reply #7 on: November 24, 2019, 03:17:34 AM »
There's a link in his original post though it shows as currently unavailable.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
