Author Topic: Starter won’t stop cranking  (Read 874 times)
Lilrick98
« on: November 21, 2019, 05:30:53 PM »
I started my agility without a problem. After it warmed up the bike completely died once I pulled on the brake lever. The bike now has no power at all. I couldn’t even use the kick start. Charged my battery & when installed it the starter stays cranking even when the ignition switch is off. I’m guessing the starter relay is shot. Any advise would be greatly appreciated.
eamartin
Re: Starter won’t stop cranking
« Reply #1 on: November 21, 2019, 09:11:58 PM »
When you said that the bike "now has no power at all" do you mean it starts but won't hardly go or do you mean it does not start and it has no electrical power? If you disconnect the wire going from the relay to the starter and then try to kick start , will the bike start?   If you disconnect the wire going from the relay to the starter and then hit the starter button, does the relay do anything?
