Author Topic: looking for 12v wire only active after you open the Ignition Switch  (Read 2347 times)
ModChiP
downtown 300 2014.
looking for 12v wire only active after you open the Ignition Switch.
near the battery.
tnx!
Re: looking for 12v wire only active after you open the Ignition Switch
« Reply #1 on: November 27, 2019, 05:45:04 PM »
Trying to understand your request. 12 volt wire AT the ignition switch is red with white stripe. The ignition switch is not near the battery on the DT300i or any other bike that I know of. But the fat red wire from the + post on the battery goes to the starter relay then a smaller red wire goes to the 30 amp fuse on the fuse block above battery. Then from the other side of the fuse is that red wire with white stripe that goes to the ignition switch. That do it for ya?
stuo
« Reply #2 on: November 28, 2019, 08:55:14 PM »
Take a voltmeter, ground the black lead, put the red lead on a connection to some electrical component with the igniton switch off, should be zero volts, then turn the ignition on; if you get 12+ volts you now have what you are asking for.
2009 GV 250
ModChiP
« Reply #3 on: November 30, 2019, 02:16:15 PM »
yes!
tnx!
« Reply #4 on: November 30, 2019, 04:21:17 PM »
All right! Now make sure you tell what you find...
ModChiP
« Reply #5 on: November 30, 2019, 06:37:38 PM »
i just need a vcc wire after the Ignition Switch to hock it up the the camera relay.
« Reply #6 on: November 30, 2019, 11:31:58 PM »
What is "vcc wire?"
« Reply #7 on: December 01, 2019, 12:15:25 AM »
What is "vcc wire?"
Im guessing it is a wire to close the relay switch,
ModChiP
« Reply #8 on: December 01, 2019, 08:45:45 AM »
vcc wire is a wire that is live only after you open the Ignition Switch.
stuo
« Reply #9 on: December 06, 2019, 05:31:39 AM »
Terminology: "opening" a switch disconnects it from power; closing it turns the power on. I think you mean turning the ignition switch to the "on" position, yes?
2009 GV 250
ModChiP
« Reply #10 on: December 07, 2019, 12:40:17 PM »
yes.
Dan Hartmann
« Reply #11 on: January 14, 2020, 12:54:22 PM »
You must pull a cord from the front, there is no one at the battery. Hope the diagram can help you.
« Reply #12 on: January 14, 2020, 02:18:09 PM »
Good diagram! Different than the one I got years ago....but good! Now, what is the question?
