Author Topic: cdi cut  (Read 8041 times)
Re: cdi cut
« Reply #15 on: September 20, 2010, 10:05:16 PM »
..i know of one 2009 a50 that did not have the wire...
..think there was another 2010 that had to replace, other than cut...
..that's all i recall...
Re: cdi cut
« Reply #17 on: September 20, 2010, 10:08:15 PM »
..there is the wire...
..click on the pic for larger...
« Last Edit: September 20, 2010, 10:12:37 PM by wordslinger »
Re: cdi cut
« Reply #18 on: September 20, 2010, 10:09:03 PM »
..it'll be okay without filling it in...but yeah...
Re: cdi cut
« Reply #19 on: September 20, 2010, 10:10:26 PM »
..it's kinda hard to tell from that pic, but you may need to go a lil deeper..
Re: cdi cut
« Reply #20 on: September 20, 2010, 10:11:44 PM »
...closer in, toward the bottom...
Aaronk
Re: cdi cut
« Reply #21 on: September 20, 2010, 10:12:13 PM »
do i cut it where yours is cut more on the right?
Re: cdi cut
« Reply #22 on: September 20, 2010, 10:15:46 PM »
..maybe deeper, toward the bottom...
..the wire should run all the way across...
Re: cdi cut
« Reply #23 on: September 20, 2010, 10:17:00 PM »
..there's nothing in that area you can hurt...
Aaronk
Re: cdi cut
« Reply #24 on: September 20, 2010, 10:22:58 PM »
oh right i'll give it a go tomorrow cheers
Re: cdi cut
« Reply #25 on: September 20, 2010, 10:23:23 PM »
..it COULD BE...
..that the wire moved a bit when that epoxy was filled in over the circuit board assembly...
..i mean, that's all this thing is...a circuit board with various components sitting in a plastic tub, filled in with epoxy, that hardened after it was filled...
..that wire would be free to move around a bit, i would think, during assembly....
Aaronk
Re: cdi cut
« Reply #26 on: September 20, 2010, 10:27:46 PM »
I haven't used any eproxy yet, oh right nvm i know what you mean
so the wire goes round inside the plastic case and it don't matter where i cut it?
« Last Edit: September 20, 2010, 10:30:37 PM by Aaronk »
Re: cdi cut
« Reply #27 on: September 20, 2010, 10:31:27 PM »
...shouldn't matter...mines ground down all across...
Aaronk
Re: cdi cut
« Reply #28 on: September 20, 2010, 10:32:01 PM »
lol ok i'll give it a go
Re: cdi cut
« Reply #29 on: September 20, 2010, 10:33:27 PM »
...kinda looks like, from you pic, that y' just aint got there yet...
