Author Topic: Beam problem with my CDI  (Read 8599 times)
le ted
Re: Beam problem with my CDI
« Reply #15 on: September 23, 2010, 08:55:08 PM »
Sorry i don't translate: Hello, where's my box of light control in my byke please?
« Reply #16 on: September 24, 2010, 12:04:44 AM »
..i think there might be a 7amp fuse beneath your front cowling....
le ted
« Reply #17 on: September 24, 2010, 05:52:59 AM »
G'day Le Ted, I have just found a manual for the super8 and it shows as being a 4 stroke, you wouldn't have the manual for the 2 stroke would you?
The wires in your picture, going from left to right, top row then bottom row, are the colours
Blue/Yellow, green/black, green.
Bottom row
black/blue, black/purple, black/white?
Hi, Sorry sidthesloth my belt have broke yesterday...My kymco is in Kymco center of my town. I can't look the color of the wire(black/white?) as soon as I get my bike I will advise you of the precise color of the thread. meanwhile I hope to have information about the GY6 Cie about  Cdi for french Super 8.
If I have some  information I give it  on the site for comunoty. I'm stuck in mud with this failure....
sidthesloth
  • Kymco ZX50
« Reply #18 on: September 24, 2010, 06:31:18 AM »
Gday Le Ted, looking at the wiring diagram for the 4 t and there is a black/red wire from the cdi to the light box.
le ted
« Reply #19 on: September 25, 2010, 10:27:28 AM »
Gday sidthesloth, do you think it's necessary to do a shunt?   I received my bike in 8 days, i wait the response of GY6 (perhaps it's my Derestricting CDI who have a problem!!!) thanks to speak with about my problem...
sidthesloth
  • Kymco ZX50
« Reply #20 on: September 25, 2010, 11:01:11 AM »
I thought a gy6 cai was for a four stroke engine, but, if your engine is running ok it might just be a matter of finding which wire to connect to the light control box. I cant seem to find a manual for the super 8 2 stroke.
« Reply #21 on: September 27, 2010, 12:03:43 AM »
..anything "gy6" is for a 4-stroke...
sidthesloth
  • Kymco ZX50
« Reply #22 on: September 27, 2010, 07:12:28 AM »
I think some things are compatible, stator being one of them and I think some CDI s.
« Reply #23 on: September 28, 2010, 07:03:52 AM »
...yup..i can interchange a LOT of parts between the ppl and the guilty...
turbokit
« Reply #24 on: October 08, 2010, 09:18:41 PM »
scootergrisen
    • scootergrisen
« Reply #25 on: October 14, 2010, 08:55:54 PM »
Hi i think its because the CDI you have bought does not make a signal for the light control box.
If no signal is made the front light (long and short) will not come on. But you can still use the positioninglight so you have a little bit light on the front.
This i speciel for the Kymco Super 8 (I have the 4 stroke version) because it uses 2 front light bulb i guess they desided to use a light control box.
Anyway you can use the original CDI box and the light will work again.
Or you can make some homemade wires.
I had a picture from a guy who bought a use super 8 and there was a homemade wire so i think the light would always be on if the ignition was on. I cant find the pictures but i have aske the person if he still got them.
You see the signal on the picture is the signal from the CDI though the black/red wire to the light control box.
« Last Edit: October 14, 2010, 09:00:22 PM by scootergrisen »
scootergrisen
    • scootergrisen
« Reply #26 on: October 14, 2010, 09:54:49 PM »
Normaly the light control box and the front light has a 7 amp fuse that they dont have to share with others.
If you do like the pictures from motorcyclephilippines.com i think that might blow the fuse.
The current to the front light will now go through another 7 amp fuse.
This other 7 amp fuse i also being used for other electric systems... like the automatic choke, winker relay and light, starter relay, brake light, clock, fuelmeter, instrument light.
If im correct the 2 front light bulbs is using 5,8 amps alone so that only leaves 1,2 amps for the others before the fuse blow.
Brake light is 1,75 amps.
Winker light is 1,6 amps.
So if you do the wires like motorcyclephilippines.com and turn the ignition to ON, hold the brake to active the brakelight and use the winker i think this will be able to blow the fuse.
Its difficult to read what they are talking about on motorcyclephilippines.com but they are also writing about changing the 7 amp fuse with a 10 amp and even a 15 amp.
I would not recomend changing the fuse to bigger fuses to fix the problem. The fuses is protecting the electrical system.
« Last Edit: October 14, 2010, 10:02:21 PM by scootergrisen »
sidthesloth
  • Kymco ZX50
« Reply #27 on: October 15, 2010, 02:24:53 AM »
The black/red wire, is that the one from tgpe pulrer coil?
turbokit
« Reply #28 on: October 15, 2010, 03:26:57 PM »
Hey, try that's shown on the picture, I did that and it works perfect!
scootergrisen
    • scootergrisen
« Reply #29 on: October 15, 2010, 06:29:34 PM »
No the black/red wire goes from the CDI box to the light control box.
