Author Topic: Feeling hit in the variator when release the throttle  (Read 639 times)
Yoni159
« on: January 15, 2020, 01:07:37 PM »
I feel when i put gas on my scooter and release it then i feel a strong hit in the variator its coomon also when i come to stop like something hit me behind . I oped the variator box and saw it coming from the variator (the pully) maybe its a crankshaft i dont know... But its only when the scooter go from speed to almost stop. In high speed its not happend.you can see in the beginning of the video that when i put gas on and release it then its make a hit sound. And also my scooter very vibrates in the first 20kmh like if feel something wrong
« Last Edit: January 15, 2020, 01:28:47 PM by Yoni159 »
Re: Feeling hit in the variator when release the throttle
« Reply #1 on: January 15, 2020, 05:55:15 PM »
Good video on streamable. Sounds normal to me. There is quite a bit of backlash (rotation slack) in those gearboxes. Maybe that is what you are hearing/feeling. You may want to inspect the splines front and back of the CVT and the spline for the back wheel.
Yoni159
« Reply #2 on: January 15, 2020, 06:26:03 PM »
The drive belt in great shape . But i feel it from the pully when i put gas on and release it when it comes to stop i feel a hit. When i ride on the scooter its also Push me allitlle bit.it can be bad crankshaft?
« Reply #3 on: January 15, 2020, 06:45:42 PM »
Not crankshaft in my opinion because if it were a "bad crankshaft" you would hear real bad noises whether moving or not. This is driveline related. Get someone local to ride with you and tell us what they say.
« Reply #4 on: January 15, 2020, 08:22:03 PM »
Two questions:
1) has your expert mechanic found anything wrong with this scooter other than the oil leak?
2) Is this your first scooter?
« Reply #5 on: January 15, 2020, 08:54:50 PM »
would be easier to trouble shoot if you had stated age/total miles/age of belt and miles of use.    As veteran of over 400,000 miles with rubber band drive scooter----I see nothing wrong if belt is fresh.  Just ride until something breaks.
Yoni159
« Reply #6 on: January 15, 2020, 08:59:57 PM »
My belt is new with only 6000km on it. Many mechanics was taking my scooter to test drive but they dont find something worng.. i dont know maybe they dont feel it or something..
My scooter is 2015 model 36000 km and yes its my first scooter.oil level checked regularly
« Last Edit: January 15, 2020, 09:02:00 PM by Yoni159 »
