Author Topic: Oil Viscoity experience  (Read 456 times)
« on: January 17, 2020, 03:13:09 AM »
Long time Japanese standard oil, for motor cycle/scooter =10-40 was the standard-----little experience here, WalMart 10-40 has worked for me for the last 500,000 miles or so with bikes/scooters and 2 Miatas.  Never a problem But, I remember buying a new Helix (Fusion) in Japan (first year, 1990,) of alloy wheels and also keeping another new Helix in the US.  Japanese market recommended 10-30, US market 10-40-----I noticed the Japan market bike ran like electric motor at higher speeds----the US market bike on 10-40 never was/were so smooth (in total I had 4 new Helix and over 175,000 miles with them).  Parts book showed no differences in the bikes.
Now, my 2019 XTown 300I----changed oil the other day, had bottle of WalMart 10-30 on the shelf---tried it and I noticed smoother high speed running down the Freeway-----Could be only in my head but I did noticed difference in both Helix and the XTown----10-30 hurts nothing with water cooling.
Re: Oil Viscoity experience
« Reply #1 on: January 17, 2020, 12:14:37 PM »
Several times over the years I've heard people say they notice a difference in engine performance, and sometimes a difference in the exhaust sound,
when changing to different oils.
I don't buy it.
It would take a bunch of blind tests to convince me.
But then, why do new cars specify 0W20 oil?!....I am assuming it is to increase MPG, by lightening load on engine.
« Reply #2 on: January 17, 2020, 12:21:55 PM »
Me, no difference in engine performance, just smoother feeling going down the highway.
« Reply #3 on: January 17, 2020, 07:04:13 PM »
You are probably correct, John, because I would guess the windage drag would be less with lower viscosity just like aero drag is related to an equivalent viscosity factor expressed in the Reynolds Number of a given shape. The smaller the RN, the less the drag. Small planes have a small RN will go faster than a larger plane with the same engine. Kinda seems obvious put that way, doesn't it! Well, that's the way!
MJR
« Reply #4 on: January 18, 2020, 02:46:37 AM »
The owners manuals have a chart of different oil viscosities you can use depending on your operating conditions. Regular automotive oil is fine as long as your bike doesn't have a wet clutch that shares enine oil. If it has a wet clutch that shares engine oil you need an oil rated JASO MA for wet clutches because modern automotive oil have additives that will damage the wet clutch. When I bought my first Burgman 650 back in 2003 those energy saving additives that cause damage were not around.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
