Author Topic: My kymco super 9 doesent take high rpm  (Read 1376 times)
Nico Hakala
« on: January 30, 2020, 08:35:29 PM »
I have a brand new 70cc big bore kit from naraku on it and 17.5mm carburator naraku (both are brand new). When i start it it runs well and the idling is good. I can drive it but when it gets to like 30km/h it doesnt go anymore. It doesent take more rpms. Before the install the scooter had been in a garage for 3-4 years and not touched. Anyone have any ideas why this happens?
« Last Edit: January 30, 2020, 08:38:43 PM by Nico Hakala »
Re: My kymco super 9 doesent take high rpm
« Reply #1 on: January 30, 2020, 10:53:10 PM »
You using the same carburetor?
Nico Hakala
« Reply #2 on: January 31, 2020, 11:13:46 AM »
Im using a 17.5mm naraku.
eamartin
« Reply #3 on: January 31, 2020, 11:36:42 AM »
What are the jet sizes?  What is the air filter set-up?
« Reply #4 on: January 31, 2020, 04:03:09 PM »
Is that the same-as-original-the-one-the-factory-installed when the bike was unmodified? You see, I have no idea what was standard for this model. And I would not know a Naraku if it bit me. Eamartin asked good questions about jets. All the answers you supply will help in solving your problem.
Nico Hakala
« Reply #5 on: February 01, 2020, 05:31:32 PM »
95 main jet and original air filter.
« Last Edit: February 06, 2020, 08:00:58 PM by Nico Hakala »
eamartin
« Reply #6 on: February 01, 2020, 10:52:24 PM »
Have you tried to removing the air filter element  and running it?
Nico Hakala
« Reply #7 on: February 06, 2020, 07:58:01 PM »
Yes i have tried that.
Nico Hakala
« Reply #8 on: February 06, 2020, 07:59:46 PM »
Now it takes high rpm when the tire is off the ground but when i drive it it just goes 30km/h max.
eamartin
« Reply #9 on: February 06, 2020, 09:03:29 PM »
How did it run before the big bore kit was installed?  What was its' top speed then?  Did it rev okay?  How many kilometers on the bike?
scooterfan
« Reply #10 on: February 07, 2020, 06:51:09 AM »
Did you the CVT driving system ? Make sure the Variator shaft, bush, and rollers are clean, and the rollers are in good condition. The clutch assembly could have a problem as well.
The reasoning for my comments - I think if the CVT system has a problem at the Variator or clutch (i.e. clutch spring), the driving system could “gear up” too fast and the engine will not have sufficient power to drive the scooter forward.
Just a guess of cause.
Nico Hakala
« Reply #11 on: February 17, 2020, 07:53:43 PM »
Now it works pretty good. The problem was the exhaust. I replaced it with a leovince hand made tt i think and now it works fine. Just need it to get more fuel. Installing 100-105 main jet.
