Over two season used my Downtown and pass 13 000km (full milage 28000) the clattering noise is present from the beginning. As I got to know my bike month to month and pass many service hours I try to localize this weird sound also. The bike does not have any failure which are not solved by brainstorm and calmness, but this problem suprasses me. I am willing to spend time and money on this, take of the engine if I needed to.
Appreciate any help from you and I watch every weird story if you share your experiences. ![Huh ???](https://www.kymcoforum.com/Smileys/default/huh.gif)
Please watch my video, I try to explain, the noise came from the crankchase or the lower part of the engine, loudest at low rpm and cold engine and same on summer time when very hot. As you can see the belt and variator removed, because many technician suggest me, that noise came from there, but I knew it wasn't. That noise easly be shown to turning the crankchase by hand
![Sad :(](https://www.kymcoforum.com/Smileys/default/sad.gif)
When I bought the used bike, does not have that sound, some clattering sound came occasionally, but not always.
Good to know:I check valve clearance 4 times (every oil change), not measured differencies, good
I check chain tensioner not stuck, put back as service book request
Replace coolant (just 2 years change) not have any sign leaks or contamination
Replace the spark plug use suggested torque, working and light brown color
To locate that weird noise I plan to remove cylinder head and cylinder piston first, maybe not expensive to change gaskets, but I can check piston pin and crancshaft-rod clearance.
If there nothing special, second remove the right crankchase cover, that is the hardest for me, because there is many parts which need special tools and good skill
I hope does not need to separate the crankcase....
