Author Topic: Compagno 110i  (Read 651 times)
springer
Compagno 110i
« on: February 20, 2020, 06:56:42 PM »
I found this https://www.repairmanual.com/product/cyclepedia-kymco-compagno-110i-scooter-printed-service-manual/
I've made a few other posts about this, so to make it short, stolen scooter, thieves cut off the connectors that connect the switch to the wiring harness.  If anyone has this manual, could you check to see if it has a picture of the wiring at those two points? If i just knew which wire went where i might be able to wire it directly into the switch. If that is even possible. With it being a kymco the wires are not color coordinated.
I cant fathom spending well over 300 dollars for new harness and lock just so i can get new connectors... that seems ridiculous to me. I'm sure i could find 4p connectors somewhere online like digikey or mouser.
Also, is it weird that this scooter doesnt have a kickstart option? I'm not really that familiar with things outside of the locksmithing realm but it seems odd that if you cant start it electrically you're just sol?
big blue
Re: Compagno 110i
« Reply #1 on: February 20, 2020, 09:06:11 PM »
Sorry I can't help with the manual but the reason that the fuel injected models have no kick start is the electric fuel pump. Battery power is necessary for the fuel pressure needed for the injector to charge the cylinder.
JJJoseph
  • Kymco Sento
Re: Compagno 110i
« Reply #2 on: February 27, 2020, 10:29:26 PM »
If the wires are cut, can you not just join them back together?  There's only 3 maybe 4 wires.
