Author Topic: Antifreeze change  (Read 933 times)
Yoni159
Antifreeze change
« on: February 24, 2020, 07:57:54 PM »
Can i drain the coolant without open the drain 8mm bolt? Mabey i can disconnected the hose?
Re: Antifreeze change
« Reply #1 on: February 25, 2020, 01:25:45 PM »
Yoni, Nothing wrong with coming here  for help - just wanted you to know that you can also quickly find answers to many of your questions by obtaining a service manual for your scooter from a source such as cyclepedia.com.
Yoni159
« Reply #2 on: February 25, 2020, 08:55:38 PM »
Its cost money
« Reply #3 on: February 25, 2020, 09:50:53 PM »
mousejunks
« Reply #4 on: February 26, 2020, 12:36:12 AM »
If you disconnect the hose near the coolant pump the result is the same. The coolant will drain out.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Yoni159
« Reply #5 on: March 03, 2020, 08:24:48 PM »
sure?? Because the drain bolt is in a lower point in the pump
mousejunks
« Reply #6 on: March 03, 2020, 09:59:28 PM »
Why are you trying so hard to avoid the drain bolt? It's right there. Just use it.
rdhood
  • Dahlonega, GA
« Reply #7 on: March 06, 2020, 04:53:46 PM »
Did mine this morning.  Now I need to go for a test ride and check things out. I'll top off the fluid,  if needed, and call it done.
2013 Downtown 300i
2013 Piaggio BV350
2014 Vespa GTS 300i
2016 Vespa GTS 300i
Yoni159
« Reply #8 on: March 08, 2020, 09:57:05 AM »
Cant open it.. my rachet too big
