Author Topic: blinker problem  (Read 287 times)
af1974
blinker problem
« on: March 19, 2020, 04:31:36 PM »
I replaced wiring harness on 2016 kymco gti 300.  when i turned key on left blinker was on and wont shut off even after scooter started
Re: blinker problem
« Reply #1 on: March 19, 2020, 06:15:59 PM »
As in THE ENTIRE WIRING HARNESS? Why?
I am thinking if everything else is working check the connector to the turn signal switch. There may be a bent pin in that connector. Other than that a swich malfunction. Don't think there was a Hazard four-way flasher on the GTi 300, was there?
Where are you located?
