2012 Agility 50... I replaced the carburetor last summer. But now after sitting all Winter (added Stabil to gas), it is hard to start. I had to use starting fluid and start it several times. Starts then quits after 2-3 seconds. After starting like this about 3-4 times it will finally run and I let it warm up by idling then it is fine.
Could fuel be draining out of the carburetor or fuel line? Could that little "vacuum operated fuel pump" be the problem? I'm not sure what to change or look at next.
Any ideas, please? Thanks!
