Author Topic: Stripped Exhaust Stud Help  (Read 723 times)
TBR125
  • East Tennessee, USA
« on: April 06, 2020, 03:45:17 PM »
My exhaust stud pulled out from the head on my agility under spec torque.
Any cheap repair options? I know my head is cheap but would prefer not to change that.
Re: Stripped Exhaust Stud Help
« Reply #1 on: April 06, 2020, 03:58:27 PM »
Same thing happened to a LIKE200i owner in Austria - "torque wrench"
He has a thread here, somewhere, think he had to finally send it to a shop for drilling and coil if memory serves.
You're an experienced scooter wrencher - I'm surprised you used a torque wrench on such a small fitting?
Torque wrenches are so very rarely recalibrated for accuracy - critical on small ones.
TBR125
« Reply #2 on: April 06, 2020, 05:12:37 PM »
I invested in a 1/4 inch precision spring dial wrench. I have found proper torque and a locking mechanism to be a crucial part of maintenance after a variator nut flew the coop.
I drilled and tapped the head for a larger bolt then used a die to re-cut the protruding bolt to M8-1.25. Time consuming but free.
« Reply #3 on: April 06, 2020, 06:45:24 PM »
All primed to brag an Helicoil wannabee thread insert but you already nailed it!
TBR125
« Reply #4 on: April 06, 2020, 10:30:23 PM »
I drilled and tapped the center of a bolt to thread the stud into. The first one was drilled off-center because i'm using a cordless drill with an inaccurate chuck. The second one should be good when I finish it.
TBR125
« Reply #5 on: April 06, 2020, 10:31:27 PM »
I need a vise.
TBR125
« Reply #6 on: April 06, 2020, 10:32:23 PM »
Picture.
« Reply #7 on: April 12, 2020, 03:08:00 PM »
that is some damn impressive, precision drilling!
TBR125
« Reply #8 on: April 12, 2020, 05:27:42 PM »
Thanks, I'm to thrifty to buy a Helicoil. Besides, a Grade 8 insert precision cut from billet steel must be superior:)
Tromper
  • Seattlish
« Reply #9 on: April 13, 2020, 05:18:13 AM »
Nicely done.
I've seen worse done with a press.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
TBR125
« Reply #10 on: April 14, 2020, 04:14:26 AM »
Thanks Tromper, I need a press.
