To better understand the problem, when you say it "doesn't want to start" is the engine turning over but not catching, or is the starter not operating. If it is the latter then the issue is an electrical problem which someone else will have to address.
If the engine will not catch then the basics to check would be fuel, spark, air probably in that order. To check for fuel pull the spark plug and see if the end is damp, for spark press the starter switch while watching the spark plug for an arc (a dark background might help), and for air make sure the filter is reasonably clean.
Hope that helps, good luck with diagnostics.
