For test purposes, I ordered a 748mm Gates belt and installed it. Just got back from a road test. It seemed to not big as badly when taking off from a stop. I topped out at 36mph according to my Waze app, and I had an eBay tach attached, showing about 6800-6900 rpm through shifting. The belt now sits almost all the way up in the driven pulley at rest, and my variator sharpie test shows the top maybe 3mm is not rubbing off, so I might be giving up a little top speed there. (Remember that with the 736mm belt I had absolutely no sharpie left on the variator anywhere).
I ended up not ordering or installing any shims. My thinking was that with the 736mm belt rubbing so much against the boss, that adding shims would probably not cause the belt to come away from the boss much, therefore not give the belt much room to expand out in the driven pulley. Also, I had pretty much perfect sharpie on the multivator, and thought shims would probably only serve to limit how far out on the multivator the belt could ride. Am I right about that?
The scoot is used in a hilly area. Who thinks I should stay with the 748mm belt? Who thinks I should go back to the 736 belt?
See attached pics:
