Author Topic: Dying after idling  (Read 675 times)
gnvernon
  • 2012 Kymco Super8 2T
Dying after idling
« on: April 20, 2020, 10:54:45 PM »
I have a 2012 super 8 50 2T that was in storage with stabilized gas for about a year and a half. I worked on it this past saturday and was able to get it up and running (even after finding a rat had been nesting in my transmission, causing everything to rust).
Once running, I can tell the idle is a bit low so I'm keeping my revs up at red lights. I tried adjusting both carb idle screws to no avail. As the idle is fading, if I try to give it any throttle, it will die almost instantly.
Any idea what this could be? Clogged jets? Clogged fuel line / filter? Appreciate the help.
eamartin
Re: Dying after idling
« Reply #1 on: April 21, 2020, 12:18:05 AM »
Have you pulled the carburetor, removed the jets and cleaned them?
gnvernon
« Reply #2 on: April 21, 2020, 02:14:46 PM »
I have not yet. Planning to do that this weekend if not resolved by then, but was hoping I wouldn't have to. It's been a few years since I removed it to install larger jets so any video tutorials you have would be helpful!
Tromper
  • Seattlish
« Reply #3 on: April 21, 2020, 07:19:37 PM »
Just for grins.
Have you checked your valves, & while at it checked your vacuum system including your PAIR tube.
I had that crack on my S200.  It caused a similar issue.  Think it was a $12 part at the time or something.  If that is it order the gasket(s) for it as well. I forgot to, but had some appropriate material around from an earlier project so was able to make 'em, but it was a PITA.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
« Reply #4 on: April 22, 2020, 11:07:05 PM »
mine would idle fine last year (S200) but if I gave it any throttle at all it would die. Classic symptoms of a clogged pilot jet. The opening in the jet isn't much bigger than a thick human hair and clogs easily. Not sure if this is your issue but cleaning the main and pilot jets would seem to be a wise thing to do after sitting for a year and a half.
Plenty of youtube videos on cleaning GY6 50cc carbs.
I disconnected just enough stuff to be able to flip my carb over to remove float bowl to get at jets.
gnvernon
« Reply #5 on: May 09, 2020, 09:20:26 PM »
So I was able to find some time to take the carb out and clean it... let’s just say it definitely needed a good cleaning.
After re-installing, I kickstarted it, and it fired right up. However, it died shortly thereafter likely due to improper tuning which I expected. But since then, I haven’t been able to start it. It sounds like the engine is flooded, but even when turning the mix screw to a lean mix, I get nothing. Any idea what to do? I tried using starting fluid and even that’s not helping it turn over.
Appreciate the help
eamartin
« Reply #6 on: May 09, 2020, 10:55:52 PM »
When you cleaned the carburetor did you removed the jets, clean them and look to be sure you could see daylight through both of them?
gnvernon
« Reply #7 on: May 16, 2020, 11:11:45 PM »
After cleaning them, yes I could see daylight through them. Was very happy with how clean I was able to get them.
Good news - I took the spark plug out and let it air out a bit and I was able to start it up within 3 kicks. It immediately idled super high and I turned the speed down a bit to be able to drive it a bit. Warmed it up and started adjusting the mix screw first, then the speed screw. It’s now idling great! Just need to figure out my starter now.
Appreciate the guidance everyone!
