Author Topic: Fuse Issues  (Read 445 times)
greglou617
Fuse Issues
« on: April 30, 2020, 04:17:45 PM »
Situation: Pulled into my neighborhood the other day, and I look down; The display and all dash electronics are blank! No speedo, lights, Sig lights, nothing. But I still had throttle response. A friendly member of the FB group helped me determine that the fuse had blown(second in from the left) and I put the spare in. Boom, it started right back up, and everything worked. I took it for a test drive, and within two minutes, the dash was blank again. Worth noting that engine code 09 has been flashing for several weeks, which says it’s a faulty MAP sensor, but I checked on that previously, and couldn’t find any problems. I know I can get more fuses,  but how do I troubleshoot this, and prevent any more blown fuses? Also, how do I fix the 09 engine code? Any help would be appreciated. Thanks!
Re: Fuse Issues
« Reply #1 on: April 30, 2020, 05:49:31 PM »
Scooter's miles & age?
Wet recently? Crashes?
Battery cables, main frame ground point, tight & clean?
greglou617
Re: Fuse Issues
« Reply #2 on: April 30, 2020, 06:03:48 PM »
It’s a 2015 downtown 300, with 5K miles. Never crashed(at least not by me, and doesn’t appear to have any damage) , and I keep it in my car port, although I’m not sure how the previous owner stored it. The engine bay looks spotless.
Re: Fuse Issues
« Reply #3 on: May 01, 2020, 01:59:14 PM »
This problem can occur with any of the Kymco EFI systems since the most all use virtually the same components.
