Did you miss your
activation email
Scooters - 50cc
Correct tire pressure
Topic: Correct tire pressure (Read 1250 times)
Rianna
September 25, 2010, 06:58:49 PM »
My front tire pressure reads @ 25, that's what it calls for as far as I know, but the tire says 32 psi on it. Did they put the wrong tire on?
juice
Re: Correct tire pressure
September 25, 2010, 07:22:00 PM »
It's really a matter of personal preference , 25psi may be recommended but you can put 32psi if you prefer a stiffer ride , more mpg and more mph . I run 32psi in both my scoots . Good luck with the stuck allen wrench .
Rianna
September 25, 2010, 07:30:54 PM »
lol, thanks, juice! I appreciate it.
omfgdotcodotuk
Sr. Member
fookin quick gilera ice 50/70cc malossified ish
Reply #3 on:
September 25, 2010, 07:59:45 PM »
if you stike a medium ie half way between the maximum and minimum you cant go that wrong,you will get good mpg and mph plus a reasonable comfy ride 28 psi would be a good start
Never ride faster than your guardian angel can fly
Back
