Author Topic: Introduction and things to come  (Read 1015 times)
liquidblackracing
Re: Introduction and things to come
« Reply #15 on: May 26, 2020, 04:10:32 AM »
Hey Iahawk,
Thanks for the insight.  I ended up buying a syringe and ill will be redoing the service.  So good to know that the rubber is EPDM and can be reused I will end up readjusting the valves as well.
thanks for the heads up.
2018 like 200i
94 cbr 600, 02 vfr 800
« Reply #16 on: May 26, 2020, 11:58:32 AM »
Yours was the first report of a dirty airfilter on a LIKE200i that I can recall.
Most of us have spares in a drawer that seemingly will outlive us.
I keep checking my airfilter - but have never found it to be dirty.
You and I must ride on different roads or in pretty different environments?
and, yeah - you won't need a spare valve cover gasket...until you do :)
« Reply #17 on: May 26, 2020, 10:33:23 PM »
Lowering bike not good idea from safety or handling standpoint.  Make sure shoe has or gets bike license.
liquidblackracing
« Reply #18 on: May 27, 2020, 03:03:22 AM »
As for the air filter, the guy said he had taken it off-roading  ??? and that's another reason he took off the center stand :/ a lot of question marks from that guy.  but hey if your wanting to get out from under an air filter ill buy it off you :P
Also turns out that the weld nuts to the center stand was completely stripped.  I had to drill threw and put a bolt-on. the hardest part of the whole ordeal was to get the spring back on.    took 2 people a jack prybars and vice grips to get it back on lol.
« Last Edit: May 27, 2020, 03:14:40 AM by liquidblackracing »
2018 like 200i
« Reply #19 on: May 27, 2020, 12:48:24 PM »
I think the first LIKE DIY youtube I ever saw many yrs ago involved changing the air filter.
It was helpful to see how the lower side panel was removed.
TBR125
  • East Tennessee, USA
« Reply #20 on: May 27, 2020, 01:17:46 PM »
Not to go flying off the handle (pun intended), but your hammer head in the pic looks pretty far up the haft.
Great work with the kick stand. I understand the pain over the stand spring. I was dumb enough to pull mine for ground clearance and then realized how hard maintenance was without it. Definitely a bear to put back on.
liquidblackracing
« Reply #21 on: May 28, 2020, 02:27:27 AM »
Lol so that was my gf family hammer. I asked my gf to go get me a hammer from the tool box and brought over the most sketchy one lol. Since then i put a screw in the top fixing that issue.
As for the tires not sure if its new new or not. The front is a China tire Kenda. Not sure if that's was stock or not but the back one is a Michelin City grip. Both have good life on them at least 80% or better. Just not sure on why on the difrent brands.  Maybe they only had one in stock or bought at difrent times by different owners.
2018 like 200i
« Reply #22 on: May 28, 2020, 03:45:50 PM »
LIKE scooters (50's and 163's) came with Kendas - hard as nails - and about as much fun in the wet.
Rear tires wear out first. City Grip was a great choice!
