Author Topic: What is proper reset procedure for ECU errors  (Read 3339 times)
kbosak
« on: May 09, 2020, 08:33:42 PM »
My problem is that service manual was written by drunken idiots and I am guessing what they might have meant.
Accordign to Service manual,
error code readout is simple and it works:
-key position off
-throttle full
-key on, engage ignition switch
-led is lit for 2s, then 3 s off, then on again and
-at that moment you have to release the throttle
Readout starts, and I got all error codes listed what this motorcycle ever had. Several of them are completely fixed, for example relays are up to spec under load, 100% sure, and yet I am failing to reset the codes.
Let me quote error readout procedure that WORKS:
SELF-DIAGNOSTIC PROCEDURES
STEP-1
“key OFF ”? The throttle should be open and
hold fully
STEP-2
“key ON ” ?the CELP lamp will light for two
second then off.
Waiting for the CELP lamp again light
The throttle should be close.
The CELP lamp will to start output failure
Signs.( failure codes to use of long?short lamp to
collocate glisten showed)
When more than one failure occurs, the CELP
lamp shows the codes in the order of lowest
number to highest number. For example, if the
indicator blinks once, after code off 4 seconds
and comes on 4 seconds, then blink 2 times, two
failures have occurred. Follow codes 1 and 2.
Now there is reset procedue I have problem understanding, since it does NOT WORK:
CLEAR- FAILURE CODES PROCEDURES
STEP-1
You should be failure parts or Sensors to
exclude. .
STEP-2
hold fully
STEP-2 :o
second then off.
The throttle should be open and hold
fully.(waiting for 10 seconds?)
The CELP lamp don’t output failure codes.
Finish. Clear failure codes procedures
My approach was simply from the above, that I have turned key and ignition on, then basically held throttle open at least 10s after second CELP lamp on. But then nothing, silence, and readout of codes returns all again.
Any clues how to clear the codes? Already tried disconnecting ECU for a long time. I suspect it uses FLASH or FRAM memory.
BTW my error codes are:
02
03
04
05
08
10
31
34
37
38
51
51
61
62
Basically with this amount of errors this should not even start (errors for relays: fuel pump, ignition, battery voltage, sensor voltage, idle throttle sensor, TPS, fan relay, ingition driver circuit, ISC valve, camshaft position, footrest). And yes fan is workign fine and enables when hot, motorcycle runs very well without overheating, I am maintaining it since 2 years but at last I would like to hunt all remaining problems.
Any idea howto?
Note: this is not that ECU is stupid and has random mix of errors, for example ignition errors concern only front cylinder and not rear one, and the mortorcycle truly had ingnition problems on the front cylinder initially two years ago.
« Last Edit: May 09, 2020, 08:38:10 PM by kbosak »
Re: What is proper reset procedure for ECU errors
« Reply #1 on: May 10, 2020, 12:51:55 AM »
Disconnect battery for 30 seconds or longer to remove codes. I dint know the Venox had EFI!
kbosak
« Reply #2 on: May 10, 2020, 12:49:40 PM »
I have completely disconnected ECU fo several hours so it shoudl have been reset.
I am afraid now that ECU is broken.
Of course it has ECU and its code is 3920A-LBF2-E00 or similar.
« Reply #3 on: May 10, 2020, 01:00:43 PM »
www.cyclepedia.com sells a service manual for your bike.
« Reply #4 on: May 10, 2020, 08:07:08 PM »
I would be surprised if the ECU was defective in any way. Not impossible but nearly improbable. I have no ready explanation for code retention other than the problems still exist. Or there may be a rather massive connectivity problem. The fact that it still runs tells lots about what still works.
Hopefully, you could find someone with a Kymco analyzer tool. That may be more effective at removing the codes and/or diagnose what is really wrong.
